Yeah, but if MeCannibal hits Firefly Paul will take more damage :proud:
How?
By KOing itself with that over powered ring, duh
Did you read that I toned it down? Its at the end of Heat C, I said I was toning it down to stop the dancing.
Actually Jamie, you should design Firefly for real - it would make a great realie :proud:
I doesnt say in the stats you can do that...
It doesnt HAVE to be in the stats. In the E.O.T.R.4 Grand Final, Joey removed the says to go weaponless in the final. Kody let me for some bizarre reason only the mind of Frank can explain :proud:
Well if you use a speed controller to regulate the speed of the ring of course you can tone the weapon down. I do that all the time with my real spinners.
Tactics: Spin, move in a direction, spin again, hit one of my opponents, spin some more, hopefully damage opponents, ummmm... spin, avoid Infusions weaponry, probably spin the body, open the pit and spin.
Oh, and spin. I think I forgot that.
Will you be using your spinner then Dan? :)
Ummm, yes. Did I not make myself clear?? :wink:
