quote:
All in all, Baldur is nowhere near as impervious as Alex might like us to think. Sorry Alex
LOL! I said that 12+ months ago...
Tick...tock...tick...tock...
BONG!!!
Sorry, Matty, but your time is now officially UP! I have no choice to wipe your spot, and replace it. :sad:
The person who was quickest to reserve Mattys now dunfunct spot (over MSN) was...MARTYN FORSYTH!!! :proud:
So get those entries in, Martyn. :)
Well if Id ever had to fight the thing with a spinner before Id have said it before now :proud:
Okay, Ive just been told, by Matty over MSN, that Martyn is officially taking his spot. Dunno why. lol
So no pressure, Martyn. :wink:
Okay no more essays for a while for me, i will give you stats when i am back with them on monday as I am at home all weekend this week, so wont be back to uni till monday
Thats perfectly fine Martyn. :)
Okay, now its not perfectly fine. :P
Martyns spot is now open, but that doesnt mean he cant enter, or Matty. So, Martyn, Matty, Samuel, Danny, Joey, Chezza, one of YOU...
...can fight over the remaining spot. :proud:
(just to clarify, I need
- 3 Mayhem entries
- 2 All-Star entries
- 1 Challenge Belt entry
- 1 Pinball entry
- 1 Sumo Basho entry)
Since I am omnipresent, I shall enter.
Mayhem: Gabriel, Fire And Ice, No Objections
All Stars: Im not really an all star, but Ill enter Gabriel and Nidhogg.
Challenge Belt: 147
Pinball: The Quaestor
Sumo Basho: Fire And Ice
Stats:
Gabriel
WEIGHT: 100kgs
DIMENSIONS: 100 x 75 x 50 cm
SHAPE: Elongated triangular pyramid with steep rear and very shallow front
COLOUR: Black with yellow and black chevron highlights on the joins and around the weapons.
DRIVE: 2 S28-400 Magmotors driving 2 wheels running off 4 NiCd packs at 24v
SPEED: 14mph average, 20mph max
GROUND CLEARANCE: 0 at front due to spring hinged nose, rising to 7mm at rear
ARMOUR: 3mm aluminium baseplate, 7mm titanium armour on rest of body (7mm hardox in critical areas and edges).
WEAPONS: A high pressure pneumatic front hinged flipper, consisting of the front edge of the body, running from 2 2.5kg CO2 tanks and a hydraulic ram giving 35 flips in a match and capable of flipping 100kgs and lifting several times more than that. Also has hardened steel spikes located on either side of the front point, and it can spin in place to try and do damage with these.
SRIMECH: Via the weapon, which should have enough force to pull it over if it becomes stranded on its back.
NOTES: Components shock mounted for protection vs. spinners and impacts
STRENGTHS: Difficult to get a grip on due to the shape
WEAKNESSES: So-so armour
Fire And Ice
WEIGHT: 110kgs
DIMENSIONS: 80 x 60 x 25 cm
SHAPE: Invertible box, with a wedge at the front and an inverted wedge at the back.
COLOUR: Flame red and yellow at front, icy blue and green at back.
DRIVE: 4 LEM130 motors running off NiCd packs at 36hp (36v) driving steel-reinforced rubber tracks.
SPEED: 16mph average, 25mph max (rarely used as it is difficult/impossible to turn at this speed)
GROUND CLEARANCE: 10mm at sides, hinged plating extending below both wedges giving zero clearance on whichever side is down (if that makes sense...), 23cm at rear.
ARMOUR: Sides ,front and rear are 6mm hardox, with the top and underside being 4mm titanium.
WEAPONS: Mainly relies on speed and ramming power, but also has two 20cm diameter diamond edged sawblades, one in the centre of each wedge (a la Angel Of Death from S2) powered by S28-150 Magmotors at 24v to around 3500rpm. The saws spin upwards to have some lifting effect as well.
SRIMECH: None, but runs inverted. Has spike strips on the sides to prevent stranding.
NOTES: Armour and components shock mounted to reduce impact from all things large and spinny.
STRENGTHS: Good speed and power, good against spinners
WEAKNESSES: Tracks vulnerable to axes
Nidhogg
WEIGHT: 100kgs
DIMENSIONS: 100 x 70 x 37 (47 inc weapon) cm
SHAPE: Elongated triangular pyramid with steep rear and very shallow front, with a flat bit on the front edge and 2 cutouts in each side panel for eyes
COLOUR: Dark green and brownish roughly chevron patterning, fading to blood red towards the front. Weapons are gold coloured with flame red spines on the arm.
DRIVE: 2 Leeson M1120046 motors run at 24v from 4 NiCd packs driving 2 wheels, with a ball caster just behind the forks in the nose
GROUND CLEARANCE: 0 at front due to forks, rising to 10mm at rear
ARMOUR: 4mm Hardox (7mm in key areas) on front, side and rear panels, 3mm aluminium baseplate
WEAPONS: Hydraulic crushing arm (constructed of hardened steel and aluminium alloy) at front driven from a Vivoil pump at 3000psi, giving 9 tonnes of force at the ram and 4.5 tonnes of force at the tip. Also has Haardvark-style lifting forks at the very front run from an S28-150 Magmotor and a lead screw capable of lifting 200kgs, generally used to hold opponents in place for the crusher to do damage.
SRIMECH: Via the weapon, which has decorative spines to assist in self righting. Spikes at the rear prevent the robot getting stranded.
NOTES: Components and armour shock mounted for protection against large scary spinny things. Eyes in side of robot serve as targeting lasers (they dont actually target, they just look really cool)
STRENGTHS: Can cause a lot of damage
WEAKNESSES: Slow at self righting
147
WEIGHT: 100kgs
DIMENSIONS: 105 x 60 x 50 cm
SHAPE: Wedge with flat back
COLOUR: Green on the front (thanks to the felt) with brown wood-effect sides and rear
DRIVE: 2 S28-150 Magmotors running from 4 NiCd packs at 24v driving 2 wheels
SPEED: 15mph average, 20mph max
GROUND CLEARANCE: 0 all around due to a hinged plate on the flipper and side and rear skirts, 10mm underneath
ARMOUR: 4mm Hardox on front, sides and rear (front covered in 2mm green felt, sides and rear covered in 1mm wood-effect fibreglass), 3mm aluminium baseplate and under flipper to deter inquisitive pointy nasty spiky things.
WEAPONS: High pressure pneumatic rear hinged flipper, consisting of the entire front plate of the robot, running from 2 rams and 2 2kg CO2 tanks, giving about 20 flips per fight. Also has a 50cm long steel pneumatic ram at the rear, running from 1 2kg CO2 tank at low pressure, painted to resemble a snooker cue (complete with chalking) which can punch through thin (2mm) titanium but is primarily there to right the robot if it becomes stranded.
SRIMECH: Via weapons. Sides have fibreglass moulding and spikes to prevent stranding.
NOTES: Has several snooker balls (1 cue ball, 4 reds, 1 yellow, 1 blue and 1 black if anyones interested) screwed to the top part of the flipper that not only look good but prevent opponents driving off/over the top. Internal components are shock mounted to reduce damage. Design theme came about as an attempt to differentiate my wedge flipper from everyone elses wedge flipper.
STRENGTHS: Powerful flipper
WEAKNESSES: Flammable (oh yes...), no real damaging weaponry
No Objections
WEIGHT: 100kgs
DIMENSIONS: 140 x 140 x 15 cm
SHAPE: A low dome type shape
COLOUR: Yellow, with a yellow and black striped lifter with red forks, and stylised black arrowheads on each side. The spinner rim is metal-coloured.
DRIVE: 2 S28-400 Magmotors driving 2 wheels, with a fairly narrow wheelbase to increase rotation speed, running at 24v from 4 NiCd packs.
SPEED: About 12mph average when driving normally, can get up to 40mph when spinning
GROUND CLEARANCE: 7mm all around, except at the front where the forks make it 0. 1mm in places because of the blades.
ARMOUR: 3mm titanium/vanadium alloy on top of 5mm UHMW on the top of the robot, supported by a 4mm Hardox frame underneath with holes drilled to reduce weight. 3mm aluminium baseplate.
WEAPONS: Complicated this...it has an electric lifting arm running off a 1 tonne linear actuator, pivoting from the rear of the robot with two front forks to get underneath opponents. The arm can lift 250kgs easily and extends fully (almost vertical) in about 1.5 seconds. Also, the robot has the capability to be a full body spinner (a spin-in-place one as opposed to a Ziggo or Gyrobot) with an outer 1.2cm Hardox ring with two blades/teeth, one on each side, made of hardened tool steel set close to the floor (1-2mm) and capable of delivering (energy)
SRIMECH: The lifter
NOTES: Internal components shockproofed to protect it from its own and other peoples spinner hits.
STRENGTHS: Versatile, can cause some damage, manoeuvrable
WEAKNESSES: Large area to attack, top armour not as strong as it could be, cannot translate while spinning
That was quick...
Joey, you are in, and this tournament is starting again!
Refreshed line-ups will posted on the Zlayerz/Varying Every Day board in a minute. Just recording the C&B2 events. :)
*is infinitely jealous of the person with his own forum* :proud:
I frogot Quaestors stats, sorry...
Quaestor
WEIGHT: 100kgs
DIMENSIONS: 95 x 55 x 30 cm
SHAPE: Box with wedge, only the wedge is in two sections making something of a shallow plow shape.
COLOUR: Yellow and blue chevrons, with gold trim on the edges and silver weaponry. Has The Quaestor spelled out on the side in anodised aluminium letters.
DRIVE: 4 S28-400 Magmotors driving 4 wheels running off 4 NiCd packs at 24v.
SPEED: 15mph average, 25mph under 36v boost
GROUND CLEARANCE: Wheels can be pneumatically raised/lowered (using a compressed air system seperate from the axe pneumatics) to give a minimum of 0 all around (this grounds it however) with a maximum of 50mm clearance, but normally has 5mm with 0 at the tip of the body.
ARMOUR: 4mm hardox front, sides and rear with 3mm titanium and 4mm polycarbonate on the top and 3mm aluminium base.
WEAPONS: Pneumatic axe on the front, running from a rack and pinion system and 2 2.5kg CO2 tanks giving about 40 hits in a match. The axe head is shaped similarly to Shunts but is tungsten tipped, weighs 5kg and can punch through 6mm titanium and dent hardox. Also has a big spike on the back.
SRIMECH: Via the weapon, which should be powerful enough to pull it over if it gets stranded on its sides.
NOTES: Base is coated with silicone rubber sheet to make it more difficult to push when in sit down mode. Internal components shock mounted for protection.
STRENGTHS: Very difficult to push or flip, good weapon
WEAKNESSES: Armour could be better, raising/lowering system takes a second or so to work
I found the stats, dont worry :proud:
Still need Aarons last Mayhem entrant as well.
EDIT: Scratch that, Aaron has given me his last entrant over Messenger: BiAtch (Wyfe) Beater. :proud:
Resuming battles soon. :)
(Message edited by kodster on March 13, 2008)
Hmm...
Tactics:
NIDHOGG vs. Die-Ceratops Re-Invertus
Try and get around the side and go for the wheels, get them off the ground with the forks, and crunch. Take it to the house robots if I can, or the pit.
In theory.
(Message edited by joeychevron on March 13, 2008)
Its slow to self-right, so if I can flip it over, then aim for a quick OOTA whilst its righting itself, I should be OK.
Wyfe Beater is getting a little tweaking at the moment. Found a few things didnt match the stats. Also increased the weapon power. New render to reflect the changes.
All right, Ill allow it.
Ladies and gentlemen, it gives me great displeasure to announce that Crash & Burn Xtreme...will be cancelled...
...and great pleasure to announce that it will make room for a NEW tournament! Youll found out about this one in a few. :proud:
I am going to do some hypotheticals for the rest of this. They will appear next post.
Very upset about the fate of this competition, but Im looking forward to finding out the results, and Im forward to this new competition youre opening :proud:
Oh dear...what, Kody, has your mind spewed forth for this next contest? Im sure itll be good, though.
The Crash & Burn Tournament - Extreme
The death of a tournament...
Heat A
All Stars: Sheer Heart Attack vs. Tornado - SHEER HEART ATTACK
All Stars: Nitro-Gene vs. Double Killa - NITRO-GENE
Mayhem: Metal Sonic Spin Dash vs. Ringwraith vs. Biohazard - RINGWRAITH
Sumo Basho: ForcePower 5.0 - 7.34 seconds
Vengeance: Tengu VII vs. Mass Disctruction Revolution - TENGU VII
Heat B
Mayhem: Axe-O-Lotl vs. Starstorm 2 vs. Sauron - STARSTORM 2
Pinball: Dantomkia - 160 points
Challenge Belt: Y4 vs. Liar - LIAR
All-Stars: Firestorm V vs. Nightmare - FIRESTORM V
All-Stars: Wedge Devolution vs. Son of Ripper 5.5 - SON OF RIPPER 5.5
Heat C
All-Stars: Die-Ceratops Re-Invertus vs. Nidhogg - NIDHOGG
All-Stars: Black and White vs. The Crashing Bore - THE CRASHING BORE
Mayhem: MeCannibal [new] vs. Tempest Evil-er-oution vs. Baldur Gamma - TEMPEST EVIL-ER-OUTION
Challenge Belt: Liar vs. MeCannibal [new] - MECANNIBAL
Vengeance: Hypertension Mk 3 vs. Wedge Devolution - WEDGE DEVOLUTION
Heat D
All-Stars: Achilles vs. Killotine Evo - ACHILLES
All-Stars: Tazbot vs. Gabriel - GABRIEL
Challenge Belt: MeCannibal vs. All Scoop and No Stab Make Steve a Dull Boy - ALL SCOOP AND NO STAB MAKE STEVE A DULL BOY
Sumo Basho: Enter the May Tracks - 11.72 seconds
Mayhem: GeForce 4.0 vs. Storm II vs. A Night at the Bar - GEFORCE 4.0
Football: Spring-BOK! vs. Back to Rock 2 vs. Revenge of the Revenge of the Bludgeonator vs. GigaByte Evilution - BACK TO ROCK 2
Heat E
All-Stars: MeCannibal [new] vs. The Disc 5 - THE DISC 5
All-Stars: Orka MK4 vs. M.O.R.D. 2 - M.O.R.D. 2
Mayhem: Fire and Ice vs. Wyfe Beater vs. Crusher C.U. - WYFE BEATER
Challenge Belt: All Scoop and No Stab Make Steve A Dull Boy vs. Sauron - SAURON
Disc-O Ball: MeCannibal [old] vs. Mega Masher 2 vs. A Night at the Bar vs. Rogue - MEGA MASHER 2
Heat F
All-Stars: Sauron vs. Wedgas Revenge - SAURON
All-Stars: Back to Rock 2 vs. Tengu VII - BACK TO ROCK 2
Mayhem: Aneurysm vs. ArchAngel of the Abyss vs. Typhoon 2 - ARCHANGEL OF THE ABYSS
Challenge Belt: Sauron vs. Snakebite IV - SAURON
Vengeance: Son of Ripper 5.5 vs. Metal Sonic Spin Dash - METAL SONIC SPIN DASH
Heat G
Northern Annihilator: Ringwraith vs. Starstorm 2 vs. Tempest Evil-er-oution (:proud:) vs. GeForce 4.0 vs. Wyfe Beater vs. ArchAngel of the Abyss - RINGWRAITH
Heat H
All-Star Quarter-Final 1: Nidhogg vs. Nitro-Gene - NITRO-GENE
All-Star Quarter-Final 2: The Disc 5 vs. Firestorm V - THE DISC 5
Mayhem: Battle Raptor IV vs. Gabriel vs. Surgeon General - BATTLE RAPTOR IV
Challenge Belt: Sauron vs. Psyclonised - PSYCLONISED
Vengeance: Orka MK4 vs. Clawdius Decimus Murderous - ORKA MK 4
Pinball: Drilla Killa 7 - 145 points
Crushing Calamity: Crusher C.U. vs. Axe-O-Lotl vs. Axe to Fall vs. Clawdius Decimus Murderous - CLAWDIUS DECIMUS MURDEROUS
Heat I
All-Star Quarter-Final 3: Sheer Heart Attack vs. M.O.R.D. 2 - SHEER HEART ATTACK
All-Star Quarter-Final 4: Achilles vs. Son of Ripper 5.5 - SON OF RIPPER 5.5
Challenge Belt: Psyclonised vs. 147 - PSYCLONISED
Sumo Basho: Cyclone Force 2.5 - 8.77 seconds
Pinball: Sheer Heart Attack - 185 points
Mayhem: Leprosy Infection vs. Whirligig 4.0 vs. Liar - LEPROSY INFECTION
Vengeance: Slammer V vs The Disc 5 - SLAMMER V :uhoh:
Heat J
Vengeance: Drilla Killa Renaissance vs. Drilla Killa 7 - DRILLA KILLA 7
Mayhem: Mass Disctruction Revolution vs. SYNDOS vs. Overkill - MASS DISCTRUCTION REVOLUTION
Challenge Belt: Psyclonised vs. NSBFR-X - PSYCLONISED
Sumo Basho: Fire and Ice - 6.49 seconds
Pinball: Leprosy Infection - 215 points
All-Star Quarter-Final 5: The Crashing Bore vs. Gabriel - GABRIEL
All-Star Quarter-Final 6: Back to Rock 2 vs. Sauron - SAURON
Heat K
All-Star Eliminator 1: Back to Rock 2 vs. Gabriel vs. The Disc 5 - Gabriel OUT
All-Star Eliminator 2: Son of Ripper 5.5 vs. Nitro-Gene vs. Sheer Heart Attack - Sheer Heart Attack OUT
Mayhem: Nitro-Gene vs. Tengu VII vs. Yet Another Cut Above The Rest - NITRO-GENE
Pinball: Flux - 110 points
Vengeance: Tengu VII vs. Crash Bandi-Bot - TENGU VII
Sumo Basho: Back to Rock 2 - 15.22 seconds
Flipper Frenzy: Invertex vs. Die-Ceratops Re-Invertus vs. Liar vs. Wedge Devolution - DIE-CERATOPS RE-INVERTUS
Heat L
All-Star Semi-Final 1: Nitro-Gene vs. Back to Rock 2 - BACK TO ROCK 2
All-Star Semi-Final 2: Son of Ripper 5.5 vs. The Disc 5 - SON OF RIPPER 5.5
Pinball: OmniForce - 155 points
Vengeance: Flick of the Wrist vs. Crusher C.U. - FLICK OF THE WRIST
Challenge Belt: Psyclonised vs. Achilles - PSYCLONISED
Sumo Basho: Tenderizers Revenge 2 - 10.08 seconds
Mayhem: Crash Bandi-bot vs. No Objections vs. Terrorhurtz - NO OBJECTIONS
Heat M
Mayhem: Axe to Fall vs. Turbo Tails vs. IDSFA - AXE TO FALL
Pinball: The Quaestor - 190 points
Sumo Basho: Metal Sonic Spin Dash - 3.34 seconds!
Sumo Basho: A.R.R.T.D.S. - Got shoved out in 47.45 seconds.
Ramming Rave: Flux vs. Cyclone Force 2.5 vs. Flick of the Wrist vs. Knightrous Wedge - KNIGHTROUS WEDGE
Heat N
Southern Annihilator: Battle Raptor IV vs. Leprosy Infection vs. Mass Disctruction Revolution vs. Nitro-Gene vs. No Objections vs. Axe to Fall - NO OBJECTIONS
Heat O
Pinball Final: The Botles Reunited - 260 points
Challenge Belt Final: Psyclonised vs. Razer - PSYCLONISED
House Robot Rebellion: Crusher C.U. & Obliteration & Flick of the Wrist vs. Obelix Bulguous & Exa-Gore-Ic: AI & Tira-san - THE HOUSE ROBOTS WON...
Mayhem Final: Ringwraith vs. No Objections - RINGWRAITH
All-Star Final: Back to Rock 2 vs. Son of Ripper 5.5 - SON OF RIPPER 5.5
Pinball Winner: The Botles Reunited (Steven McGregor) with 260 points!
Sumo Basho Winner: Metal Sonic Spin Dash (Steven McGregor) who shoved Asterix Heroicus off the arena in 3.34 seconds!
Football Winner: Back to Rock 2 (Martijn M Benschop)
Disc-O Ball Winner: Mega Masher 2 (Christopher Mason)
Crushing Calamity Winner: Clawdius Decimus Murderous (Steven McGregor)
Flipper Frenzy Winner: Die-Ceratops Re-Invertus (Christopher Mason)
Ramming Rave Winner: Knightrous Wedge (Aaron Knight)
Challenge Belt Winner: Psyclonised (Andrew Jackson)
Mayhem Winner: Ringwraith (Richard Southworth)
All-Star Winner: Son of Ripper 5.5 (Andrew Jackson)
Thanks to everyone who joined...shame it had to be a hypothetical, but I must get this out of the way before I start my new tournament.
It is over.
WAHEY! Even though it was a hypo, and I cant be sure you didnt just pull the results out of...Wales...No Objections did really well considering. :)
WOOT! I did quite well all things considered - I held onto the challenge belt, I made the Annihilator and 4th in the All-Stars, and I assissted in taking out the current C&B Champ in the All-Stars! WOOT Im taking part in the next thing you do :proud:!
Oh, I thought that Sauron beat Back To Rock in the All-Stars Quarters.
So, by the end of it all...
ORKA MK 4: Got revenge over CDM
DIE-CERATOPS REINVERTUS: Won the Flipper Frenzy
CYCLONE FORCE 2.5: Did fairly well in the Sumo.
LEPROSY INFECTION: Got into the annihilator.
MEGA MASHER 2: Won The Disc battle.
Y4: N/A
AXE-O-LOTL: N/A
OBLITERATION: N/A
CRASH BANDI-BOT 3: N/A
SPRING-BOK!: N/A
And regardless of being hypothetical or not, those will be their last fights in their old forms. I now have the new and improved ones to use.
(Message edited by Dinowarrior on March 16, 2008)
:lame:
All-Star Quarter-Final 6: Back to Rock 2 vs. Sauron - BACK TO ROCK 2
