http://i.imgur.com/LaDAX90.jpg
Shiny newness next to busted oldness.
Spin up while in the robot. Bad noise I think is due to lack of lube. 3s just to make double super safety sure it wasn't going to explode. Also belt tension is a bit loose. Meh. fixable.
https://www.youtube.com/watch?v=l65dK021OCo
That's a massive upgrade from last year, looking forward to seeing it in action!
https://www.youtube.com/watch?v=LxIpfhOLeXU
I got all the electronics in a mostly working order now :) Cheers people.
Looks deadly! Are you going to make some kind of cover for that link? I'd be worried about axes or flying robots knocking it out/ bending it.
http://i.imgur.com/lJj5wem.jpg
Yeah it has a hollow tube that it sits in for a bit more protection.
With the robot totally complete it measures 13.1kg on my scales. I want to go for side guards but don't want to push my luck. No idea how accurate or reliable this scale is.
http://i.imgur.com/2rCH7iS.jpg
Got to tidy up and secure all the wiring but at this stage there isn't much more I can do.
Assuming those scales are accurate I think you've got enough weight for wheel guards, 500g get you a piece of 15mm HDPE 60*600mm which I imagine is just about enough to make basic guards against horizontal spinners. You can always take them off at the champs if they push you over the weight limit.
That's too large of an assumption for me to really be comfortable with. I've got a piece of 2mm Ti that would be better for the Nick -style wheel guards. But then the mounts and the bolts add some weight there. I can pocket out some of the panels some more although I don''t really care too.
Hmmmm
Well, Massacre is 99% done. The spare spare belts are on their way and fingers crossed I get them before I leave. Banged out a cradle for it to sit on and got all the sharp edge protection/locking clamps on.
Having a bit of mixer trouble though, its one of the GWS gold ones that failsafes. It doesn't let the robot turn. Whichever direction I move the stick it only goes forwards and backwards, which as you can imagine is not what you want when trying to turn. Any ideas on what to do, or does anyone have a spare?
Thank you.
Sounds obvious but are you sure steering channel is plugged into the receiver correctly or that there isn't a break in in of the wires? You could try plugging the steering channel into another channel eg. Rudder or throttle to see if it works? Do you have mixing turned on on the transmitter.
Yeah I've got mixing off. Turned it on to see if would somehow help, ofc it didn't so I turned it back off.
EDIT: steering works on rud, cheers bud.
Are you using dx6i? Why not just use the built in mixing with the dual rates set so you get 100% throws?
DX5e peasant here.
Also now mixes but don't failsafe any more. Just rebound it with the new set up and no joy.
I have some spare spektrum receivers you could borrow which may help remove some of your issues.
Cheers mate, appreciate it.
ouch, thats a bit of a ding there
Better luck next time Harry, it looked like a really good machine but it just got unlucky. Hopefully you can get it running for next years champs and it will dish out some major damage
Cheers Sam. Same goes for Hatchet :)
Did the bar get bent?
Thats some big damage
I havent seen the videos yet as ive been deprived of wifi for the whole of the champs due to being on holiday
Got to make some sacrifices hey
He had 2 bars, but yes one got bent by conker 3, like a banana, and his 3.2mm Hardox base also got a HUGE dent in it.
Originally Posted by
harry hills
Wow... did Conker 3 do that to the bottom of Massacre! I never knew!
Really dude? You told and showed everyone you spoke to what you did to massacre for a couple days at champs.
Sorry, that repost was only meant to show the bottom of the robot. I remember the bar, I have that on video.
