Re: The tournament formerly known as FFW
Add in Killotine: EVO (same as always) and Venus Fly Trap II for me, ta. :)
Venus Fly Trap II
SHAPE- box with wedges on all sides
COLOUR- green with ugly great mouth on top
WEIGHT- about 100kg, I hope.
DIMENSIONS- 95cm X 95cm X 20cm
SPEED- 12mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- 10mm, though the wedges and spatulas should provide some extra protection
ARMOUR- 3.75mm Hardox
MOVEMENT- 4 x inner wheels
POWER- 2 x C40-500 MagMotors. These will run at 36v and produce approximately 12hp.
WEAPONS- On either side of Venus Fly Trap II is what appear a rear-hinged flipper with a large spatula, covered in barbs. These are the 'jaws' and are powered by an 80mm x 120mm pneumatic ram each, running at 250psi. The idea is that an opponent is scooped up on top of the robot or gets stuck on one of the spatulas, the 'jaws' fire simultaneously and ensnare it like a real venus fly trap.
SRIMECH- A rear-hinged arm on top. Powered by a separate S28-400 MagMotor geared 250:1 for quick and easy self-righting.
NOTES- flies Scotland flag, thanks to Joey for aiding in the design
STRENGTHS- Unique weaponry, powerful, well-protected, nimble
PIC- http://img394.imageshack.us/img394/7102 ... trapii.png
Two realies now, Steve. ;)
Bleh. Brain no thinky so good.
Swap out Killotine with the latest Terrorhurtz then, please, Mr Z.
That's cool :)
Tracy's last 2 needed and 1 more entry pleeeeeease.
Oh darn it, my internet is playing up all the time, hopefully its not too late
Sauron
Weight: 80-100kg, depending on the setup used.
Shape: The robot without any setup on it is shaped like Tornado, back when they didn't have the interchangeable weapons.
Colour: Black, with a picture of The One Ring on top.
Dimensions: 85cm x 75cm x 25cm
Drive: 4x S28-400 Magmotors, powered by 3x 25.9v 5000mAh LiPo battery packs.
Locomotion: 4 Goodyear go-kart wheels.
Armour: 4mm titanium
Speed: 15mph
Ground Clearance: 0mm at sides and back due to skirts. 5mm without skirts. The front ground clearance varies with the setups, but unless otherwise noted is 5mm.
Turning Circle: 0m
Weapon: 7 different interchangeable setups.
1: A 20kg hardox scoop, designed to kill spinners. 0mm ground clearance at the front.
2: A 10kg hardox scoop like the one above, but with a Pneumatic axe powered by 2 2kg Co2 tanks using a 3kg Terrorhurtz-style axehead and a 100mm stroke 180mm ram at 200psi. It can strike with around 600kg of force, and can be recessed into the body of the robot, keeping it invertible. 0mm ground clearance at the front.
3: A set of Panic Attack-style lifting forks, powered by a 50:1 reduced 25.9v S28-400 Magmotor. It can lift 250kg. 0mm ground clearance under the forks.
4: A Behemoth-style lifting scoop, using a 75mm bore 100mm stroke ram and a 2kg Co2 tank. It can flip 400kg and lift 500kg. 0mm ground clearance at the front.
5: A 4-bar Biohazard-style lifter, using a geared-down S28-400 Magmotor. It can lift 300kg. 0mm ground clearance at the front.
6: A 20kg hardox spinning bar on top of the robot, powered by a 25.9v S28-400 Magmotor at 4000rpm. It puts out 156kj. Another skirt is added to the front of the robot. 0mm ground clearance at the front.
7: LIke setup 6, but without the bar. 0mm ground clearance all around due to skirts.
Srimech: Invertible in all setups except for setup 6. Setups 2, 4, and 5 can all self-right the robot.
Strengths: 7 WEAPON SETUPS!!!
Weaknesses: There has to be at least 1 problem with each setup.
Bio: The first Team Blood Mages robot with interchangeable weaponry. Will it work? We'll see...
Win/Loss Ratio: N/A
Empty Inside
Weight: 100kg
Shape: Storm 2, a box with wedges on the front and sides, with a rounded back
Colour: Camo, with shades of red
Dimensions: Height 25cm Width: 65cm Length: 105cm
Drive: 2x 24v S28-400 Magmotors, powered by 5x 3000mAh NiCad Battlepacks.
Locomotion: 2 Storm 2 style wheels, like Merlin, are positioned at the front
Armour: 6mm titanium
Speed: 12mph
Ground Clearance: 0mm, under the flipper and 0mm elsewhere except the back thanks to Titanium skirting, 5mm with out skirts though
Weapon:An Achilles style rear-hinged flipper,which is attached from the back and goes all the way down the front to the bottom of the wedge. powered by a 750pi 2.5kg C02 tank, with 2 70mm bore 300mm stroke rams which power the flipper. Can flip up to 300kg and can lift up to 400kg, much like Achilles itself, it is a full body flipper, which means that the front wedge and the top, fire towards the back of the robot, the sides do not flip up though
Scrimech: The flipper of course
Strength: Powerful weapon
Weakness: Dunno
BIO: Another new design for 2011
Win/loss ratio: N/A
rated I for: This bot is in the hands of an Idiot
http://s276.photobucket.com/albums/kk11 ... icDoom.jpg
Metallic Doom
Weight: 150kg
Shape: A low box ala Drillzilla.
Colour: The left half is red, while the right half is black.
Dimensions: 107cm x 95cm x 17cm
Drive: 2 36.3v LEM-130 motors powered by 11x A123 Battlepacks
Locomotion: 2 Drillzilla-style shuffling feet, giving Metallic Doom good traction and pushing ability.
Armour: 3.25mm hardox
Speed: 20mph
Ground Clearance: 0mm at the front, 5mm elsewhere.
Turning Circle: 0m
Weapon: A pair of horizontal crushing jaws, each which looks like the one used by Suicidal Tendencies, powered by a Vivoil Pump and LEM-130. Each jaw has a 2:1 ratio giving it 9 tonnes at the ram and 4.5 tonnes at the tip.
Srimech: Invertible.
Strengths: Nothing wrong overall.
Weaknesses: Average everything.
Bio: The 6th Team Blood Mages(a subsidiary of Death Robotics) creation is rather average overall...
Win/Loss Ratio: N/A
EDIT: Thanks to mr Kody for the excellente CAD
The Servant's Assistant
Weight: 100kg
Shape: Box with a wedge on the front ala Mortis
Colour: Behemoth style yellow and black stripes
Dimensions: 0.36m x 0.76m x 0.91m
Drive: 4x 24v S28-400 Magmotors, powered by 5x 3000mAh NiCad Battlepacks
Locomotion: 6 internally mounted solid rubber wheels.
Armour: 6mm thick Titanium all over. 3mm Polycarbonate baseplate
Speed: Limited to 18 mph. Can reach 40mph.
Turning Circle: Zilch
Ground Clearance: 0mm at the front. 8mm elsewhere
Weapons: A full-pressure rear-hinged Co2 flipper which starts off from the back of the robot and finishes at the bottom of the front wedge powered by a fire extinguisher using a 70mm bore 100mm stroke ram. It can flip 500kg.
Srimech: The flipper of course. Hubs on the sides to stop it being stranded
Strenghs: Fast despite speed cap. Good flipper
Weakness: Not sure
Bio: The Servant takes on a new shape and armour. Will do proud. Or will it flop. Only time will tell
Win/Loss Ratio: N/A
Rest to Follow, if im still allowed into this. Sorry guys
Me and Joey are helping Tracy with a new vapourbot for this. :) As for another realie, that's her problem. :P
Lian that's fine. Please try and do it fairly soon though as I'm itching to start :P
Will do mate, im at my nans this weekend (Infact im at her house now) so it should be done in the next day or 2
Shadow Zone Forevermore is now up on my forum, let's see how bad it does :P
Heres my other 4
Nurse Pain
Weight: 150kg
Shape: Son of Whyachi (Battlebots 3.0)
Colour: The chassis is green, the weapon is black, and the bracing rods are blue.
Dimensions: 110cm x 80cm x 30cm
Drive: 2 C40-300 Magmotors at 36.3 volts, geared 4.5:1, powered by 11 M1 A123 Li-Ion cells.
Locomotion: 2 Drillzilla-style shuffling feet.
Armour: 10mm hardox for the tribar, and 3mm titanium for the main body.
Speed: 12mph
Ground Clearance: 1mm all around due to the hammers almost touching the ground. 5mm under the body of the robot.
Turning Circle: Zero.
Weapons: The weapon is a deadly 21kg Son of Whyachi-style tribar powered by 2 36.3v LEM-130 motors at 4000rpm. Each end of the tribar has a 3kg Hardox hammerhead attached to it. It can put out 277.5kj. It also has bracing rods that are part of the tribar, and therefore give the tribar the full 21kg of weight.
Srimech: None
Strength: Absolutely deadly. Can kill almost anything.
Weakness: No srimech, but that won't matter.
Bio: Nurse Pain has no shockproofing. Basicaly its a bot for laughs and comedic perpouses
Win/Loss Ratio: N/A
Druid 2.0
Weight: 100kg
Shape: Reptirron the 2nd (S6)
Colour: Black on the right-hand side. Gold on the left.
Dimensions: 82cm x 90cm x 60cm
Drive: 4x 24v S28-400 Magmotors, powered by 4x 3000mAh NiCad Battlepacks
Locomotion: 4 internally mounted Biohazrd-style wheels.
Armour: 3mm Hardox
Speed: 12mph
Ground Clearance: 0mm at front. 9mm elsewhere.
Turning Circle: 0m
Weapon: The weapon is a rear-hinged flipper, powered by 2 2kg Co2 tanks at 750psi via a 100mm bore 150mm stroke ram. It can lift 800kg, and can flip 500kg.
Srimech: The flipper can self-right it.
Strengths: Tough, decent flipper.
Weaknesses: Previous incarnation had a habit of going out of control.
Bio: A slower, but tougher incarnation of Druid.
Win/Loss Ratio: N/A
For the realies, i'll have Slicer (Dutch Robot wars champ) and Tsunami
