http://lmgtfy.com/?q=Electronize
Oh wow... I dont even... :oops:
TBF i did google it, but on my phone, so half the results got messed up. Im still inclined to go towards the Saberooth, will have a think.
i also looked at these esc dunno if anyone's used them but they sound ok
http://www.ebay.co.uk/itm/130602511068? ... 1423.l2649
http://www.youtube.com/watch?v=zDo1X...=youtube_gdata
i might be ever so slightly bias against the sabertooth escs, do you think?
Just for that im Buying the Sabertooth...
Seriously though, i still think the Sabertooth is the better option, could i not wire in a fuse or something to lower the odds of it exploding and dying a horrible death?
regardless of the esc wiring in a fuse to the power feed to the esc is a good practice
Use the mini blade type from a car - the holders are inexpensive and there are a wide range of value
Sounds good, buying the 12a model and then wiring fuses in line, wish me luck :uhoh:
Also im in need of belts/Pulleys and links? Below is a picture of my setup ATM, the Drum (of sorts) its a steel blade i purchased from Jonny a while back, to compromise for its lack of endcaps its comes as one Unit, which is useful, just add nuts to the ends, add belts and we are ready to go
As far as I'm aware, they don't just blow, they have current cut outs, so there fine, it's the fact that the exposed circuit, gets damaged from debris and dirt and stuff, which can short, and damage the delicate electronics. I think... Just protect them in a case, and cushion the mounts maybe a good idea?
technobots for pulleys
