Your robot would go three times as fast but have 1/3 the torque and less pushing power
its hard, i need some more speed out of the motor (probably) yet i also need torque.
what is the best to have more of? torque or speed?
well if you don't have enough torque you won't be able to move. best to aim for 10mph speed (unless it's a ram bot) and hopefully you'll have the torque to move the robot around
its a single motord wheel chair from a rascel 205 with diff and top speed at maximum 154kg load of 7 miles per hour running at 12v but ill be running at 18v in the bot
well if it has a 7mph top speed at 12v giving it 18v will make it go at 1.5 times the speed so you'll get 10.5mph out of it anyway :)
how are you going to use the motor/gearbox if its only a single motor?
its a single motor yet with the diff its able to drive both motors and can turn on the spot, i really dont know how it works but it does :)
And now thinking logically I have realised that the motors is completely useless since It only does foward and back!!!!
I got free wheels basically and that's it. I need to somehow find another of the same motor of a rascal 205 and then strip the diff off it to leave me with just the two motors or downswing on the price, I might just go the old bosch 705w route
Where is the best place to buy 750's?
http://www.ellis-components.co.uk/
i beleive they sell them
I'll give them a ring tomorow and see what price they are
