...ah, I was thinking of one of Dave Lawrie's ants as that's the only one I know XD
Lian, much like I did on ARC Im also gonna confirm here that Im fine with the otherweights you gave me, and thanks to Kody for pointing out I was in need of them :D
Ok draws for the 1st 8 heats
Apocalypse II vs Eternia vs Jinx
Megaroll II vs Flirty Skirty vs orrion
heat b
Frustum vs Axe to Fall vs Compression
Fissure vs oid vs Gabriel V
heat c
Helix vs pickaxe vs Illusion of Dread
Gehenna vs V for Vendetta vs Road Block
heat d
Bandwagon 3 vs N³ vs razer
Crushtacean vs Flick of the Wrist vs Comengetorix
heat e
Exotherm vs The Final Cut vs Mantis mk2
ian vs Wedginator 9.0 vs Minesweeper 4
heat f
Loki vs Volde vs Scrap Daddy HW
Panic Attack vs Sheer Heart Attack 2 vs Wedga Triton
heat g
LockJaw v3 vs Walkies vs Absolution
The Clones That Weren't There vs crooked evo vs Eye of Ran II
heat h
Tazbot vs Holepunch 2.0 vs Maximum Genocide
bigger brother vs Reptirron the 2nd vs Extreme Gyration
Tactics. Predictions and who you think will win the heats so far :P
Heat A
I still question Apocalypse II's realism here, and if possible I'd like Liam to assuage my fears of its unrealism. :) Other than that, I shall attack it right away. My forks should get right underneath its front end, while I grapple'n'pit it. Avoid Eternia any way possible except if I'm in a dangerous position (then grapple'n'pit it instead :P)
Megaroll II vs Flirty Skirty vs Orrion
lol Flirty Skirty I think will skirt the issue and go home. :P
Heat winner: Eternia I think.
Heat B
As good as Frustum is, its weight disadvantage I think may do it in. Hopefully it might pull a Chaos 2 and prove me wrong. :P
Fissure vs O.I.D. vs Gabriel V
Gabriel and Fissure are pretty tough machine, Jack's got his work cut out for him.
Heat winner: Gabriel V
Heat C
Helix vs Pickaxe vs Illusion of Dread
Circular skirts do not work as they cannot have a fully zero ground clearance, and if it did it wouldn't be able to move. :P Turn Pickaxe over with the lifter and smack it with the bar until he dies. Encourage Helix to assist me with this and avoid him if otherwise.
Gehenna vs V for Vendetta vs Roadblock
lol Roadblock
Heat winner: I actually think I have a decent chance here, but I think Gehenna will cut me down if I meet it. Which is likely. :P
Heat D
Bandwagon 3 vs N³ vs Razer
Whoever Nidhogg decides to go after will die. Neither other competitor can stack up to him I'm afraid.
Likewise. They can't do much to Flick here. It'll be whomever Flick decides to go after.
Heat winner: Out of a N³ vs. Flick of the Wrist heat final, I'll go with N³.
Heat E
Exotherm vs The Final Cut vs Mantis Mk 2
Mantis confuses me. Unless Leo or someone else shows me exactly how it works, I deem it ineffective and I say it will go out, sorry. :P
I.A.N. vs Wedginator 9.0 vs Minesweeper 4
Hey, it's the Minesweeper with the stackable sides! Stack it. :proud: If he sneakily put spikes on the sides, however, I'm not sure how those scoops will fare. I can push my lifter into the ground too. :P Get under it, lift it, and pit it. I suggest I.A.N. helps me with this. :)
Heat winner: The Final Cut is lookin' good, WARGH!
Heat F
...Scrap Daddy??? LMAO.
Poor Panic Attack is getting on in years I reckon. :(
Heat winner: Loki looks good, but SHA2 and Wedga are real threats too.
Heat G
No, I'm not going to kill myself. :P Reason being, the shell shall be locked at 1500RPM. It'll still belt opponents across the arena and spin back up ferociously quick for another blow. :) Because I don't know Walkies' stats yet, I can't give proper tactics, so I'll just spin up and destroy anything that comes near.
The Clones That Weren't There vs CrOoKeD eVo vs Eye of Ran II
20kg against 236kJ? Jack should be smart enough to sit by sidelines and watch this unfold. :P Goodbye Mark.
Heat winner: IJ of Ran t00 ;D
Heat H
It's not my match, so I'm not too concerned, but I still would like to say Maximum Genocide is overweight with all that weaponry and those motors/batteries. It to go out, or Tazbot if this unrealism goes unnoticed. :P
Bigger Brother vs Reptirron the 2nd vs Extreme Gyration
When Aaron made Gyrate, he didn't intend it to really WIN, per say. It was made to just to achieve a huge, huge kJ count and prove a point (correct me if I'm wrong, though, Aaron :) ). It was borderline in the weight limit as it is, and when Mark adds armour/shockproofing to it, he just makes it overweight, so Mark should be DQ'd or forced to change his stats. Again, not my match, but writers should really watch for these things.
As for the match? EG to explode on contact with something instantly, and BB and Reptirron to advance.
Heat winner: Holepunch 2.0 looks to be the only one to stand a chance here, lol
Whoops that reminds me.
Otherweights
Heat A
feathers
Stiff Breeze vs Redemption vs Small System Shock
lightweights
Anti-Virus 3.0 vs Hit 'em Hard vs Sergeant Slaughter
middleweights
Hazard vs t-Minus vs Maxus
Super-Heavyweights
Puzzel vs Shovelhead vs UberForce 2.0
Heat B
Featherweights
Starfighter(1#) vs Skink vs Micro Gore Evo
Lightweights
No Redemption vs Lightning LW vs Minilith
Middleweights
259 vs Terminus vs sub-zero
Super Heavyweights
UberForce 2.0 vs Inflammatory Slammer 2 vs Tax Cutter's Return
Heat C
Featherweights
flow vs Storm Vortex vs Scoopy Doo
Lightweights
Fang vs Fuzzel vs Wedgehog
Middleweights
The Unnamed Feeling vs Gamma-Rex vs Striker
Super-Heavyweights
Tetris vs Drive vs Omega-Rex
Rest to follow :P
In that case I'll wait a bit. :roll:Quote:
Originally Posted by death robotics
Heat D
Redemption vs NCC 1701 vs OverDrive
Lightweights
Fuzzel vs typhoon thunder vs Gamma Raptor
Middleweights
Nuzzel vs Heroin vs Hyper-Ventilate
Super-Heavyweights
Vladiator vs Demon Duck vs Ziggy
That should do it
Just need to formalise Murdertrain and Walkies stats and if people think they're ok then that will be them.
Heat I
Sideswipe vs Killertron vs Liar 2
All Bar One vs Frenzy vs Axeon 4.0
Heat J
7roubloon vs No Consequences vs Skull
Splinter vs Pussycat vs S3
Heat K
Wheely Big Cheese vs Obsidian vs Exertion II
Apples & Pears vs Darkwing 3 vs ia5
Heat L
behemoth vs Magnitude vs Symmetry
Fissure vs The Subjugator vs Firestorm
Heat M
Goldigger vs Murder Train vs The Alexandra Sisters: Retribution
Annihilation vs TAN vs M.O.E
Heat N
Matador vs GBOD vs Under Pressure
Spawn Again vs Super Gore Septua vs Thiwon
Heat O
Ge5orce vs Equinox vs Surgeon General
Still Hurting vs System Shock 5.1 vs Diotoir
Heat P
Back to Rock III vs PsycloniZer vs Voltronic
Nightmare vs Storm 2 vs Nemesis
Final predictions in for me :mrgreen:
Oh yeah Jordan. You have to use Nemesis due to Liam chosing Diotor :wink:
Revised seedings include other tournies
1: Apocolypse 2
2: Iron-Awe 5
3: Anihalation
4: Sergeon general
5: Exotherm
6: Megaroll 2
7: Helix
8: OID
9: Mineweeper 4
10: Loki
11: Crooked Evo
12: Gabriel V
13: Jinx 1.2.
14: I.A.N.
15: Bandwagon 3
16: Alexandra Sisters
17: Skull
:mrgreen:
