Overview
Three questions ...Yes ( but not enough in general to worry about )... Yes and Yes.
http://www.google.co.uk/search?hl=en&q=cordless+2+speed+drill+rpm&btnG=Sea rch&meta=cr%3DcountryUK%7CcountryGBhttp://www.google.co.uk/search?hl=en...btnG=Search&me ta=cr%3DcountryUK%7CcountryGB
Overview
Danke Schonne :proud:.
Will need that. Merci.
Grazie,
Alex :proud:
P.S Corrections on Danke schonn? I think I miss -spelt it.:uhoh:
EDIT: Will this be O.K on the torque front?
http://www.argos.co.uk/static/Produc...t%3EDRILLS.htm
(Message edited by aero_storm on October 10, 2008)
Overview
That is a corded drill and so works off 240AC not (as you are allowed in the rules) up to 36V DC.
A simple rule. If you plug the drill into the wall, it isnt useful to you. If it has a battery that needs recharging every so often and is in the voltage range of 9.6V to 36V it is useful to you.
O and stay away from hammer drills. Stopping the hammer motion is a bigger hastle than its worth.
(Message edited by typhoon_driver on October 10, 2008)
Overview
Ok. What about these. I know Im just throwing links around but this is a forum.
Thanks for the advice about the plug although the problem probably would have become clear once I had bought it :)
http://www.argos.co.uk/static/Product/partNumber/7106127/Trail/searchtext%3EDRILLS.htmhttp://www.argos.co.uk/static/Produc...rchtext%3EDRIL LS.htm
http://www.argos.co.uk/static/Product/partNumber/7111686/Trail/searchtext%3EDRILLS.htmhttp://www.argos.co.uk/static/Produc...rchtext%3EDRIL LS.htm
http://www.argos.co.uk/static/Product/partNumber/7110340/Trail/searchtext%3EDRILLS.htmhttp://www.argos.co.uk/static/Produc...rchtext%3EDRIL LS.htm
Thanks,
Alex R
Overview
Ill throw a link back at you ...one that I gave before ...http://www.4qd.co.uk/faq/roadspd.htmlhttp://www.4qd.co.uk/faq/roadspd.html
Put in the cordless drill RPM ...1,200
You will be screwing a wheel on in place of the drill chuck so ...Gear Ratio = 1
Use a wheel dia of 100mm
Output = You tell me Alex R :)
Id really like you to try and use the calculators.
The above rpm and wheel size is fairly common if your using cordless drills as drive motors.
Woody
Overview
The reason I was asking for more drill links is because the speed that a 1100 rpm drill gives me with 4 inch wheels is about 13 mph. So I have, in fact, used the calculator, and done everything you have told me to do on the calculator. This is a forum. Im not as experienced as you, but if I was I wouldnt be here.
Alex
Overview
quote:
Im not as experienced as you, but if I was I wouldnt be here. Thats not a great attitude, just leaching of the knowledge of others because you havent yet. So the second you know all you need youre out of here?
Overview
I knew that would be thrown back in my face.
No, thats not what I meant. I do appreciate the help Im getting. I was a bit irked due to the fact that despite trying my best I just wasnt good enough. But, hey, Im not experienced, I have built no robots, so Ill take what comes.
Alex
P.S Back to the topic now?
P.P.S Sorry :blush:
(Message edited by aero_storm on October 11, 2008)
Overview
Alex R ...I happily make allowances for newbies ...young or old.
Whilst I could have given you the specs for everything ...I believe its a good idea to at least make you do some homework on the subject.
So homework done.
I think for the price range your looking at ( cheap ) perhaps 4 off 9.6v drills run @ 12v with 100mm wheels giving you approx 8 mph.
Getting the higher 1000 plus rpm will probably require you to double or treble your £ spend.
Overview
Ok, thanks. My calcs say that if I overvolt a 750rpm motor with 7cm wheels, I get 13mph. This is what I will go for. Then Ill just see what happens.
Alex
