Cut out the second wheel slot today. Garage was freezing but made good progress none the less.
Attachment 7617
Drilled some fix holes in the base for the weapon motor.
Attachment 7618
Then I laid up some parts to check it will all fit together/ Never know if the drawing and reality will match.
Attachment 7619
I noticed one of the motors is branded as Actobotics and the other is another brand but same part numbers. Will check it matches.
Attachment 7620
Shocked at how small these little motors are.
Weighed every things and also measured some parts to check dimensions are as expected. Most things are coming in a little lighter. Not sure if that is my scales though.
