Looking good, but round off the corners if your going into full combat
I have just one question...
https://youtu.be/_GMpkn43qgo?t=1665
(If it doesn't work go to ?t=1665)
Looking good though! My first Bot was pretty boxy too, I was just mad enough to go in against spinners :P
Attachment 5803
Externally, the bot is finished. Just a little more wiring to do, and I'll reveal the finished product just before the Manchester event!
Hey, could I ask how you cut/drilled your HDPE? I'm about to start on mine in earnest, and wanted to see how you went about it.
Treat it as if it was wood. Coarse wood blades for sawing, wood drills, same way of connecting.
Leorcc pretty much has it right. Table saw for large and thick pieces, band saw for smaller and thinner ones, and a rotary tool for the really fine details. Always use coarse wood blades, and don't push too hard or they will clog up and blunt very quickly. Use a sharp wood drill, I learned the hard way that normal HSS drill bits grab into the plastic too fast and go through it like a corkscrew.
Hmm, interesting. Thanks a lot. :)
Ferrovore is back from its debut appearance, here's the rundown.
Pros:
- Never broke down
- Cosmetic damage only
- Weapon performed perfectly
- Successfully pitted an opponent (without diving in after it!)
Cons:
- Insufficient ground clearance, kept getting beached on debris
- Front not low enough to get under opponents efficiently
- Not enough power to use the weapon while driving flat out
- Automatic self-righting mechanism too unreliable
- Opponents held in the jaws could still push back
Modifications for next time:
- Fit larger wheels to raise the clearance and drop the front lower
- Use conventional radio control for the self-righting mechanism
- Install an independent battery for the weapon
- Figure out a way to lift the nose while biting an opponent
Watch this space for more build updates!
Attachment 5832
Great to hear it performed fairly well, certainly it seems to have survived the warzone. It'll be a shame to see the auto-srimech go though. Best of luck with the modifications!
