Any chance of getting a refund on the drill?The disk doesn't look that big and chances are that you will find various frame parts that won't fit either. More importantly, a bench drill that can't accommodate the disk probably doesn't have a motor powerful enough to run a 1" twist drill thru steel. My bench mill can only just do it and nowadays, I use a hole saw for anything over 3/4".
Probably not much chance of that unfortunately, it seems fine for little jobs and the frame bits seem to fit as far as this robot goes. I may have another solution to getting the disc bored out it just sets me back slightly. I think the best thing to do is just to save up that extra bit and get something bigger eventually if it proves a real problem.
Shame about the disc being too big. One of those awkwardly unpredictable things. I have a cheap (£40) bog standard small pillar drill (350w?) and have used it for absolutely everything. My main complaint is accuracy and that the "bed" deflects terribly, so I stick wood under it.
Anyone with a large enough lathe or a mill would be able to take the bore out quite quickly. You could also specifically ask that they true the bore's position to the circumference of the disc.
It's the fact that it *just* doesn't fit, its off by around 5mm. Hopefully I can sort something out as I'd rather not have to get a new disc made, the rest of the robot should hopefully go without any problems but time will tell.
Tiny update, after my circular saw crapped out yesterday I was left with no way of cutting out the hdpe bulkheads and supports other than hand saws, today however I've found a solution that I'd forgot I had. It's a saw blade for an angle grinder that should allow me to cut everything with at least some precision if I take it slowly. http://i921.photobucket.com/albums/a...psfe3ac833.jpg
Don't think I've seen something like that for an angle grinder! It's likely to yank you and the grinder into the work or the work into the grinder... be careful!
(and take pics)
Oh I'll be VERY careful, I'm going to take it really slowly and apply as little pressure as possible, im going to test it on an offcut first and if I'm happy it won't kill me then I'll use it.
Pretty sure thats for a circular saw... putting it on a grinder sounds dodgy
With the disk could you just cut/file/grind a small flat on 2 opposite sides where the teeth will go that takes the material back by 5mm so it can fit? Would have to be carefull to get exactly the same off each side so it stays ballanced.
It's definitely being sold as an attachment for a grinder, I'll test it on an offcut and if it's too dangerous or doesn't work then I definitely won't be using it again
