Dan the decal is misleading, but that valve should operate as follows, port (P) the one opposite to the diagram decal is the pressure side (from buffer tank). Port (A) is the user, and should be connected to the ram. Port (R) is the return, ie its the exhaust from the ram and should not be connected to anything. In the normal position, port P is closed. Port A and R are connected (air in the ram is exhausted through port R)
When solenoid is energised, Port P is connected to port A, air from buffer tank flows to the ram. Port R is closed.
