As I said before, do the sums and work out which motor will work best for you. Then design the machine around it.
Would a normal cordless drill motor do the job as a axe motor if it is geared correctly?
There is only so much power in a batterydrill motor. Gearing won't amplify it at all, just make it a tad more efficient.
I used a cordless drill motor as an axe motor on a 5:1 ratio. In short, no. There are small steel pins inside the drill gearbox that keep the small pinion gears in place, and the forces from a weapon like that just cause the pins to fail (basically falling out of the holes in which they're mounted).
If you want to go for an electric axe, have a look at electric scooter motors on eBay, specifically around 300-350W power rating. I changed my drill motor on the axe to one of these and they are vastly superior. On the same ratio the axe hits a lot harder and faster, and the motor can definitely take it. Sam also uses one for his robot Hatchet and has it working well for him.
I see, what exactly does the 5:1 ratio mean? I would guess small gear to big gear type of set up.
Yep, the drill motor had a sprocket on it with 8 teeth, and the axe had a sprocket with 40 teeth on it, connected to each other by a chain. So for every five rotations of the drill motor shaft/sprocket, the axe arm only rotated once, thus the 5:1 ratio. It reduces the speed but increases the torque (or turning force) so that it isn't as much of a struggle for the motor to turn the heavy arm.
Oh good, I guess there will be some modding to fit the small sprocket to the motor.
something like this?
http://www.ebay.co.uk/itm/24-VOLT-30...AAAOSwBLlVcco6
Yep.
As someone who's concrete garage floor has been attacked by Jamie's axe I can say that the scooter motors are indeed well suited to this application :)
