Re: Botbitz 85a esc..... in a heavy?
Not interference the motors draw the full amount of amps at low duty cycle for the part of the cycle they are on. (Low inductance means high rate of current change) So this means that you can have 200A then 0A in the PWM cycle rather than the motor acting as an inductor and smoothing this @ the PWM frequency.
This causes high loads on the capacitors and batteries and can cause the ESCs to brown out. (The voltage drops too low and the ESC resets) With the paired ESC I found that this happened as there was higher resistance in the 12AWG battery wires than the ESC and motor. And voltage sag got pretty bad.
This is not normally a problem as the ESC just resets and away you go again, but if they are paired. It can reset and just blow up as they are two individual controllers.
That's very interesting, testing Dan's new machine (with the TZ85s) we found th drive to be juddery and the Rx would also be flashing red (indicating it's browned out).
We plan on changing the battery to a higher spec to help the voltage drop.
How many cells were you using? I could see this happening on 2S but 3S+
It shouldn't unless you are using crappy batts or wiring.
Steve
This is on 3S, two Fan motors for drive (in a FW).
We assume it's just down to the motors overstretching the Li-Po in terms of current.
