How could I Improve pt 2
I was wondering something...I was intending on stealing something from Aaron from a project I am involved in, and was wondering if I could know more about hydrostatic drives and if there were any asdvantages over electric drives?
I was thinking of this thing copied from Aaron:
Drive: The drive is a hydra-static drive train. It has a 42HP Honda CR125 motor bike motor (2005 model) with a custom made swash plate hydra-static pump bolted to the motor output shaft. The hydra-static drive provides full motor torque at 0MPH right up to 40MPH (Electric motors and normal hydraulic drives cannot provide this feat, if you google hydra-static, you€™ll find out why). 6 x 120mm wheels that are 100mm wide provide the maximum traction when coated in 15mm of Urathane Rubber (Volcalon).
-but spelt correctly :proud: and a bit differently worded, lol
Basically there is no difference between hydraulic and hydrostatic motors. The one version controls its speed through speeding up or lowering the rpm of the pump, while hydrostatic keeps the pump going to maintain the same working pressure, and a valve regulates the speed and direction.
Advantages:
- Even at 1 rpm you get maximum torque
- very precise motor control
Disadvantages:
- You need more parts, so it is heavier than just a pump and motor.
- 1 bubble of air and the system either doesnt work or with way less power, even chance of damage.
- Chance of leakage is big. one leak, no pressure, no drive.
- you need to keep the pump going at all times to keep pressure up, so it takes more battery power.
What sort of power would I be looking at from such a system though? And (this might be a stupid question) is there any problem with using standard hydraulic rams in a hydrostatic system?
The same power as from any other hydraulic system, there is no difference there.
And yes you can use hydraulic rams in a hydrostatic system, in fact most diggers do.
It still looks like Atomic. :crazy:
Seriously tho, very nifty. Loving the internals, you can tell you put a lot of work into this.
looks good kody!
i have been quite keen on writing a tournament and have been flicking through the archives,so i have a good idea of how things work.
so could i have 2 robots for a battle please, if you could post them with your stats and tactics that would be helpful.
after i have posted the fight, please feel free to post any comments
jack
o wow, thats a brick to watch Kody
and that internal view makese me know where to put my axe next time I fight it :proud: still it gets you points for coolness
http://strickenone.proboards99.com/i...oard=thvapours
take something out of these Jack, Axe to Fall would be nice since Im still not sure what direction to take Axe to Fall 2 :P
(Message edited by MajinB on August 30, 2008)
You can use tempest for the other fighter. Stats below.
Tempest Evil-est-oution
Shape: Ring spinner.
Speed: 12 MPH.
Dimensions(dh): 80CM X 25 CM
Armour: The spinning ring is 1.8 CMs of Ti. The base and top are 1.5 CMs of polycarb, giving a total armour weight of around 63 KGs.
GC: 1 CM.
Weapon: Ring spinner powered by two Lem 130s and spinning at 1000 RPM to deliver 83 KJs per hit. The four hardox teeth are 10 CMs long with two being placed near the top and two near the bottom.
Drive: 2 wheeled, driven by S28-400 magmotors.
Srimech: Invertible.
Notes: Has an absolute buttload of shock proofing inside. Everything is firmly bolted down, with layers of rubber between everything. Added to that, the teeth have a backwards curving shape which maximises the distance it will throw itself away from the opponent. The reason is twofold. First is to make ramming and flipping it difficult, but the main reason is to bleed away kinetic energy backlash, by using that backlash to move the robot externally rather than internally.
Strengths: Hits hard and is hard to hit. Not much is getting through the armour.
Weaknesses: Should the spinner fail, it€™s pretty much screwed.
