Whilst I'm waiting for parts to show up for the feather weight I've been working on the heavyweight.
Finally a full pressure pneumatics test:
http://youtu.be/nQHECcujhFk
Anyone got any advice on how to stop the bushing coming out the end?
Next step is to do the wiring with a decent removable link so I can have it driving around (last time the main power wires melted!)
Then just need to sort out a flipper arm and finish off the chassis, might see if I can switch to a front hinge as I think that would put less stress on the piston rod.
New idea for the design of the drum for the fw:
http://i1261.photobucket.com/albums/...91AB04488A.jpg
Exploded view:
http://i1261.photobucket.com/albums/...C13CE10977.jpg
What do people think? Is it likely to work or am I asking for trouble?
You'll need to re-evaluate those discs, they don't look balanced. Personally I'd try a similar design but with fewer, thicker discs or have the discs more of a ring type design and key them onto the drum - more money/effort but would be a lot less likely to fail
Oh yeah, forgot to mention that the disks would be re-designed so they were actually balanced! I just haven't got round to designing them yet
You will need an even number of disks to make it balanced with half the teeth on one side and half on the other; I would go with Matt's suggestion of thicker teeth and smaller spacers. Having a sandwich of teeth and spacers reduces strength and stiffness; the axle is the main part keeping everything straight so it needs to be really strong.
How is it held together along the length of the drum?
The whole drum would be slightly in compression holding it together. The bearings are set into the end of each drum so there would be a small axial load on the bearings.
The other thing is didn't mention was that the teeth would be made of some form of steel and the spacers aluminium, so weight becomes an issue as the teeth get wider! As it stands it shoud I be about 3kg
What is applying the tension? If you are compressing the drum via the bearings, you will need tapered roller bearings; ball bearings will wear quickly. The problem with this is that tensioning bearings too much really increases their rolling resistance, so you will be wasting power overcoming bearing friction, which will be dumped as heat in the bearings. Sorry to be blunt, but my gut feeling is that this design will bend and fail after an impact with another vertical spinner.
I'm guessing this design is to allow teeth to be replaced as they wear, which is a good idea. If that is what you are after, I would go for the same design as 720's aluminium drum. It is probably no harder to make and removes all the structural problems, plus that design is field-tested and proven reliable. Mouldy made the aluminium body of the drum really thick, but you can always reduce the weight with a larger bore.
I guess the 4 rods running through it could be threaded at the end with counterbored nuts at the end to compress the whole thing together, maybe I could redesign the spacers and the disks so they sort of slide over each other/interlock to improve stiffness of the system.
The idea behind the system is to be more easy to repair/replace sections and to overcome the problems Mouldy had early on with the teeth ripping out (he had to dovetail the teeth in or something I beleive)
Mouldy used a T slot to hold the teeth in, as least on the drum that I saw. The nice thing about that is the teeth slide right out once the end of the drum is removed.
Using the rods to hold the drum together will definitely improve the stiffness but its going to need CNC accuracy to get everything aligned.
