So the horizontal claws of Hector managed to pierce though the Hardox side armour of Crooked to manage to get a hold of the battery to pull it out of the same side hole in the Hardox armour?
Do you guys mind if I interrupt the conversation and show you my latest creation....?
Pesticide
Weight: 100kg
Shape: Hexagon
Colour: Emerald Green
Dimensions: 100 X 75 X 32
Power: 2 X LEM-130€™s @ 36v powered by 90 X NiCad Cells
Tyres: 2 X Tightly Foam Packed, Asmaprene Urethane Rubber Tyres
Armour: 3.5mm Hardox 600 Everywhere
Ground Clearence: 5mm Everywhere
Turning Circle: Zero, with tank style steering
Weapon: A nasty 27kg Titanium spinning disc, simillar to Matilda€™s, (Only this time, its horizontal) powered by a LEM-130. The teeth are shaped like Hypnodisc (Series 4 version)s tooth, and are made out of hardox. This baby can spin at 3000RPM, and deals out 74 kJs. Plenty of Shock-Proofing, as well.
Srimech: Invertible
Strengths: Deadly Disc, INSANE Pushing Power
Weaknesses: Wheels Exposed, although extremely sturdy.
Can anyone check this?
Samuel,
I need a little more info. how big is the disk, and where does it mount on the hexagonal robot (partly in partly out, or on an A frame outside the robot)?
Pesticide
Weight: 100kg
Shape: Hexagon
Weapon: A nasty front (partly in) 27kg Titanium spinning disc, simillar to Matilda€™s, (Only this time, its horizontal) powered by a LEM-130. This disc is 38cm in diameter. The teeth are shaped like Hypnodisc (Series 4 version)s tooth, and are made out of hardox. This baby can spin at 3000RPM, and deals out 74 kJs. Plenty of Shock-Proofing, as well.
Srimech: Invertible
Ive not checked the KJ count, but apart from that Id say you need to get the weight down.
Armour 40 kg
LEMs 9 kg
Disc 27kg
Batts 6 kg
Wheels and gears 10 kg
For Mounts, electronics etc. 8 kg is not much, and you need twice the amount of cells you have now really.
Given the dimensions you gave on the disc, it would be 5 cm thick. you could halve that, making the disc somewhere around the 15kg mark (it would still be 1 or 2.5cm thick), and use the remaining kgs for batteries and mounts etc.
(Message edited by leorcc on August 21, 2008)
Add to the fact that a hexagon is a 2D shape...
Well I calculated it as a hexagon prism with 1 side missing for the disc to poke trough.
Fragmentor was cloned AGAIN? :rofl:
Pesticide
Weight: 100kg
Shape: Hexagonal Prism
Power: 2 X S24-800€™s @ 36v powered by 90 X NiCad Cells
Srimech: Invertible
Strengths: Deadly Dusc
quote:
S24-800€™sNever heard of them before. :)
