Pic on Profile of my new feather Ive just started to build yes they are EV Warriors for the Drive
Lookin gd, would be cool to have a feather tanto :) What speed are you aiming for?. What thickness armour are you gonna use, and what size+voltage batts?
I hope your not using those wheels in the pic, youd never get the power down with them, get some ali ones vulced or get some of the big 100/150mm Robochallenge ones from james.
Speed about 15mph should give me good pushing power. Batteries 2 12v 3700 in series. Armour will have to see what weight I have left. Speed controller Sidewinder. No I wont be useing the wheels in the pic probably make my own as they need to be 160mm.
I screw bike tyres on Alphas wheels for grip. Focus/Do It All sell some wheels about 160mm. You using a gear reduction tony?
Yes I use bike tread on Dragonstrike probably do the same on the new one. gear reduction about 4.5 to 1. Ewan if you go to http://www.teamdragon.org.ukwww.teamdragon.org.uk kishar page theres a vid of kishar spinning up its disc using the HTI motors. In fact it got stuck in Eds arena wall at Colchester.
Looks very good. Well I do have two hardox discs and four HTIs to play with :)...
ladies and gentlemen, I shall introduce you one of the toughest FW robots in 2006!
Name: not decided yet
Drive: 2x1½hp+ drills and 3 x 1½ colsons which give top speed of 20km/h
Weapon: electric FLIPPER with 2hp DeWalt (0.075 from down to up position no-load, approx. 400mm of travel. lifting force max. 625N)
Battery: 24v/3300mAh NI-MH
Speed controller: Sidewinder
Armor: 12mm pocketed 6082 T-6 aluminium frame, 3mm welded hardox front armor and 2mm garolite top/bottom, maybe some stainless on top too..
Status: almost fully designed, under construction, will be ready before next summer if everything goes right.
Notes: all the designing, machining and welding will be done by me :)
pictures: http://www.robosota.fi/foorumi/viewtopic.php?t=547http://www.robosota.fi/foorumi/viewtopic.php?t=547
You have to bring that baby to the UK!
And the Netherlands. Looks a serious project JH-Q.
quote:
one of the toughest FW robots in 2006! .... Im not convinced only after being in the arena for awhile will I accept that claim..:lol:.!
Chris - ^_^
