Ok, rather than start a new thread for every question I'll just ask them here, after some more opinions for this potential featherweight:
- what are people's opinions on using 2 brushless motors to power a single drum? They would each have their own timing belt going to the drum with toothless pulleys on the drum so they are not completely forced to go the exact same speed like they would be if you used 2 connected by gears say. Would it work? Should I use one esc or 2? Am I better to spend the same money on a single more expensive motor?
- what are opinions about using aluminium wheel hubs? I know most people who make their own use HDPE or similar but due to my design i have relatively thin walls on the hubs (5-10mm) so think I need something stronger, is the aluminiuk just going to bend if I get thrown in the air and land on the wheels?
