The Crash & Burn Tournament 2
Paul, Alex is right, I should have been aware. Im very sorry for that, and Ill try not to make that mistake again (though it probably will happen ). The only excuse I have is that I was a little tired.
Heh, sorry that I brought it up over and over in this thread. I was just planning on making a note of it once, but some people didnt catch on to ip :P
Good fights, regardless
Martyns tactics:
quote:
well go for the wheels and try and do what Thz did to smidsys wheels in extreme 2, i.e bend them out of shape and damage the chassis. he seams to forget thz was made signigifcantly stronger between between series 5 when fluffy thought it and extreme 2 which is the version i am using i think. so it could take more of the damage then it would have in series 5.
Aarons tactics:
quote:
Baldur is a very tough design, but its got some features that can help me none the less. Baldur has a lot of edges, the sides are all flat and the sides of the scoop are flat too, so I believe if it tries to ram me, Ill more then likely catch an edge and there will be a big bang as both bots go spinning apart. Even at a low 500rpm, MDU has a good 25 chances per second to hit an edge on Baldur. With the force from 100kg rotating even at the small speed and the huge drive train behind MDU, its going to get thrown around. And, the last part is, edges are bad for your armour, gives a weak spot for spinners to dig into and tear panels.
Will have the next battles up soon, if thats okay.
He seems to forget Cyclone Force is faster than S.M.I.D.S.Y, and his blade is more like that of Disc-O-Inferno, which was much more powerful than Fluffys.
Sorry Frank, but it was fair.
Fights will be up in a few days, I need more time off :crazy:
All right! First fights of 2008! :proud:
Terrorhurtz (15) vs. Cyclone Force 2.5
Terrorhurtz (15) barely survived the first round, but Mass Disctruction Ultimate 4 killed off Boxed In first.
Cyclone Force 2.5 sent out NSBFR-X on a judges decision when tying Baldur Gamma for 1st spot.
Roboteers, stand by...
Booth 1: Terrorhurtz
Booth 2: Cyclone Force 2.5
Taki-san returns again, but flanked by Ancalagon the Black this time.
3...
2...
1...
ACTIVATE!!
Both bots are out of their spots immediately, and Cyclone Force being the quicker slams into Terrorhurtz with the disc!
CRASH!
Terrorhurtz lurches around, a small dent in its front end, but nothing too serious yet, and so turns back to face Cyclone Force, to find the Storm-shaped bot retreating to spin its blade back up! Hurriedly Terrorhurtz gears towards the disc, and stops it before it can achieve deadly speeds. Cyclone Force thus is shoved back into the wall, tilted slightly. Down comes the axe...striking floor! Cyclone Force had not been idle and shifted to the right to avoid the axe, and gets away to spin up its disc. As Terrorhurtz chases him down, retracting the axe, Cyclone Force reverses into the pit release button, opening the pit once again. Terrorhurtz does not meet his front but tries to slide an attack at the side. A little sloppily, however, as Cyclone Force merely turns and catches the side!
CRASH!!!
The Series 6 Grand Finalist is sent flying by the sheer brute force of that disc, also sustaining a wider gash in the polycarbonate armour! Out comes Cyclone Force from the wall, Chris looking happy that his machine inflicted some damage, but Martyn isnt going to give in just yet. Terrorhurtz comes flying into the fray, forcing Cyclone Force to avoid the charge so his disc can reach maximum potential but he doesnt get the chance! The front wedge of Terrorhurtz finds its path to Cyclone Forces side and the 15th seeds axe flies down into Cyclone Forces top armour! It slams into the 7mm titanium armour and bounces off, actually causing hardly any damage, but the axe comes down again, and ...again, no damage, and Cyclone Force escapes. Terrorhurtz chases after him, intent on beating that titanium into a thin pulp, but he had failed to notice that Cyclone Forces disc had reached full speed during his own attack, and now it comes back to bite him as Chris turns his bot around and drives it into Terrorhurtzs front wedge!
CRASH!!!
Martyn is dismayed, as Terrorhurtz is flung across the arena, one of the panels making up the wedge ripped right off! Cyclone Force hunts him down again, disc already 3/4 of the way up to speed, but then Terrorhurtz flies at him with the rear wedge, right out of the blue!
CRASH!
Its Terrorhurtz that takes the blow but its Cyclone Force thats worse off here as Terrorhurtz has not taken any damage from that blow, nor had he been moved at all, and now throwing him up near the axe head smashes Cyclone Force into the wall! WHAM! Chris tries desperately to manoeuvre his machine away from the rampaging axebot but hes trapped against the wall, and the axe hits from reverse! WHACK! The 7mm titanium again withstands the blow but a tiny dent is now made this time, maybe not too visible, and the axe comes down again - oh! The axe shaft hit Cyclone Forces side, stopping Terrorhurtzs attack? What an interesting turn of events! Martyn seems to realize this too and moves Terrorhurtz forward a little, but in doing so Cyclone Force makes his getaway, riding off of the edge of the rear and away! It seems Terrorhurtz is becoming tired of this assault, as he is not really in a hurry to finish this, moving rather lamely across the arena...but Cyclone Force is, and that deadly disc smashes into Terrorhurtzs front end!
CRASH!!!
Cyclone Force must be impressed with itself, as Terrorhurtz is again knocked away, hit in the exact same front spot as before, devoid of the wedge, and the polycarbonate is sliced up brutally! Chris backs his machine away from the 15th seed, to find that he might not need to do much more to win, as Terrorhurtz moves with even less agility than before! Martyn is quite displeased with this result, but even more so when he sees Cyclone Force barge in with the disc again! Terrorhurtz tries to dodge the attack but at this point its...pointless! :proud:
CRASH!!!
Its the other side of the front that takes it, but that wedge takes the blow, though getting smashed up in the process. Terrorhurtz charges forward to try and take advantage but Cyclone Force is much quicker by now and backs off to spin up his disc for an attempt at a killing blow. Martyn decides to rely on the pit and Terrorhurtz moves towards it, but Cyclone Force again rushes in, disc back up at speed, right into the untorn side!
CRASH!!!
The blow sends Terrorhurtz spinning into the wall, past the pit release button, and coming to a halt between Taki-sans CPZ and the pit! Terrorhurtz does not seem to be moving now...no, it isnt! Martyn frantically works the controls but nothing seems to be working...and resignedly puts it down as The Watcher comes near and starts counting Terrorhurtz out.
And its now over and out for Terrorhurtz, as Taki confirms by shunting him down the pit.
CEASE!
Terrorhurtz (15) will be terribly hurtin in the mornin. :proud:
Cyclone Force 2.5 advances to the Heat H final!
Mass Disctruction Ultimate 4 vs. Baldur Gamma
Mass Disctruction Ultimate 4 ripped apart both of his opponents before almost bowing under his own power. Terrorhurtz joined him while Boxed In...broke apart. :proud:
Baldur Gamma tied Cyclone Force 2.5 in a judges decision, which sent NSBFR-X home to sulk.
Booth 1: Baldur Gamma
Booth 2: Mass Disctruction Ultimate 4
Asterix Heroicus spins around like a twister on steroids in his CPZ. Tira-sans blade spins slowly, almost ominously...
3...
2...
1...
ACTIVATE!!
Baldur Gamma comes FLYING right out of his spot...to meet a half-spun-up MDU4!
CRASH!!!
Baldur is sent flying right across the arena and into the far wall, right near the spinner button, seemingly taking the blow on the front well. However MDU4 is also sent flying, and in his case its not so good, as its right at Tira-sans CPZ! The house bot gives one of MDU4s three sides a taste of her blade!
CRASH!
The 4mm hardox takes the blow well, but it also sends MDU4 flying...RIGHT INTO BALDURS SCOOP! The green and purple sparks have hardly faded when Baldur cradles MDU4 into the scoop, and lifts it up, and MDU4 is slammed into and on top of Tira, Baldur crashing into them a split-second later! Asterix flies out as though that was a signal, and smashes into Baldurs rear end, throwing him skyward, and into MDU4, knocking him further into the CPZ! Tira shunts MDU4 away and goes to spin her blade back up, and Baldur pushes MDU4 away as Asterix pushes him in to have a go, and crashes into MDU4, tilting him up again! Aaron is frustrated now, trying all that he can to try and spin his beast up but its not working for him at all, and so that was good tactics by Alex and Baldur Gamma, shoving him into Tiras CPZ to stop him from rotating! Baldur decides to let Asterix have some fun and backs out of the CPZ...to have Tiras blade meet his rear end!
CRASH!!!
Baldur smashes into the wall heavily, rather undamaged, but covered in colourful sparks! :proud: Baldur turns in wrath and tackles Tira, sliding under her and shoving her all the way across the arena straight into the wall, raising the scoop as he does so! WHAM!!! Tira soars, flying up, and over onto her back! Baldur shoves into her again and stacks her up against the wall to prevent her from doing any more damage, and then goes back to the CPZ, where Asterix has released MDU4, however Aaron doesnt have much breathing room as Baldur smashes into him again before he can spin up at all! WHAM! WHAM! Straight back into the CPZ! Tira uses that srimech to get herself off the wall and back onto her wheels, and now goes after Baldur in equal wrath. MDU4 is stacked himself against the wall, but Asterix tackles him and MDU4 falls right back onto the wedge! Baldur turns to find Tiras spun up blade right in his face!
CRASH!!!
Baldur ricochets off the wall and into Asterixs side, Asterix hardly noticing, but the scoop is still intact and more or less in on piece! Tira realizes this too late, as Baldur drives into the stalled blade, and again shoves her across the arena, and raising the scoop lifts her...WHAM! Tira again flies...OVER THE FENCE!!! Just barely, though! She was stack-slammed against the wall, tilted onto the railing, and fell out! MDU4 cant get away from Asterix, but The Watcher tackles Asterix to let him know his fun time is over, but Baldur hurries back, just as MDU4 begins to finally spin up.
CRASH!
Its not monumental, but it does send Baldur lurching a little, but it does mean MDU4 gets to spin up more! Baldur turns and buries the scoop in!
CRASH!!
The crash is louder, as Baldur is flung again, farther this time, and MDU4 throws himself against the wall! Baldur Gamma spins around to let the audience know hes still alive, and then flies extremely fast, right back at MDU4s who almost achieved his full speed, his fastest yet!
CRASH!!!
Baldur is launched across the arena, even thrown into the air, but its MDU4 who takes the REAL force, catapulting back into Tiras vacated CPZ, now occupied by Asterix! The gaul-bot slams MDU4 into the CPZ opposite and holds him there, as Baldur returns to the fray, the scoop actually a little buckled now. The Watcher comes towards the CPZ and shunts Asterix again but Baldur intervenes and catches one of MDU4s blades, pushing further into the CPZ, right to the corner! Asterix backs off, but Baldur enters the CPZ and positions the scoop under MDU4! The scoop raises and lifts him against the wall! Aaron panics with the controls, but Alex is ectastic with the situation, and before Asterix can move into the CPZ again, Baldurs scoop lifts MDU4s frame up, up, AND DOWN!!! MDU4 crashes outside of the arena, defeated! What a fight!
CEASE!
Mass Disctruction Ultimate 4 has self-destructed.
Baldur Gamma advances to the Heat H Final!
Heat H Final
Cyclone Force 2.5 vs. Baldur Gamma
Tactics, predictions, comments, thoughts, and a glass of champagne for the first fights of 2008. :proud:
CYCLONES TACTICS
I think Ill go for the claws this time, and try for a quick and simple grab and pit. He can flip, so the lifter may not be as effective as Id like, and as hes shock absorbant, the disc wont be that effective. I believe Ill use the claws and my superior power, which Im fairly confident I have.
Woo, I wish Beat MDU one on one was something I could justify puttign in my awards section, lol. Very very pleased with that, great fights Kody.
Well I never really have to worry about damage, and Ill look up the stats for cycolne before I make my final decision, but initially just try and outmanouver and ram around the arena a bit, hopefully into house robots and hazards and so on.
Heat H Final
Cyclone Force 2.5 vs. Baldur Gamma - I believe this to be a very close battle. They both have the equal amounts of power, but Cyclone Force has the more traction, and I believe that Chris will triumph in winning against Baldur.
