Just going to post my character's profile.
Name- Epsilon (ε)
Gender- None (Thought referred to as Male)
Species- Android/Robot (Whichever term you prefer)
Dice Roll- 15
Stats
STRENGTH- 2
AGILITY- 3
WILL- 2
INTELLIGENCE-3
Appearance-
Designed and built in a secret laboratory located somewhere in the Dzhugdzhur Mountains of Siberia, Epsilon was a prototype combat robot. As part of its design, it utilised a unique AI system that would effectively allow it to learn and adapt to its surroundings very quickly much like a living being; albiet minus what were considered to be the negatives of human consciousness, such as emotions and frailty, which would in theory, allow it to become the perfect soldier.
However- although the robot's AI system appeared to work well, an error in applying it to Epsilon itself caused it to develop an artificial thinking 'brain' from its system, giving it self-awareness. After breaking out, eluding its creators and destroying their laboratory, it went on the run- until now.
Epsilon is humanoid in shape- its chassis is based around a super-flexible armoured skeleton that reduces damage by about 91%, and is clad predominantly in a very dark grey endoskeleton made of a specially-designed, flexible alloy that is lightweight yet extremely strong, and bends on severe impacts and retains its shape rather than breaking or shattering.
It has smooth, white panelling layered on top of this armour, predominantly on its forearms/hands, lower legs/feet, upper torso/shoulders, and pelvic region, and has a stylised ε symbol etched into one side of its torso armour, which glows blue.
Its head is covered by a white helmet with a visor in the front, concealing broad-range camera "eyes" that have a higher framerate than the normal human eye, and can adapt to see in different situations (Such as in the dark), an ultra-sensitive sound recognition system that can hear a far broader spectrum of sounds than the normal human ear, its compact supercomputer 'brain', and a built-in scanning system that allows it to temporarily copy the abilities of others. Its visor typically glows blue when powered on.
Its main weapons are concealed in its forearms- compact but powerful "Wrist Cannons" that accumulate and convert energy into powerful beams that can be fired in a variety of ways, along with being able to channel the abilities of its opponents through both its cannons and its hands as necessary.
Its body contains its primary power supply- an experimental Power Core that generates both the necessary energy to fuel all of Epsilon’s systems, and enough for a secondary supply that can be used when producing energy via normal means becomes impossible. It also contains an ultra-compact tank of Micro-Fusion fuel (In order for Epsilon to be active if his main Power Core is damaged or otherwise inactive, and his secondary supply runs out.), and a specialised Central Control System and Internal CPU capable of high mathematical logic enactment.
At the slightest sign of danger, the neuron connections simultaneously inform each section of the body to correspond. In short, this allows Epsilon to react extremely quickly to certain situations.
Its legs contain three main features- a Gyroscopic Stabiliser that enables Epsilon to land cleanly in any area, from almost any kind of state, an Acceleration System that allows it to quickly accelerate over short distances along the ground, and a powerful Thruster and Anti-Gravity device in each foot that allows it to hover and fly at high speed over short-to-medium distances.
Personality-
Due to being a robot, Epsilon appears to lack personality initially- quiet and emotionless. However, with its thinking 'brain', it does actually have one, albeit quite in-line with its initial purpose- very intelligent, but rather cold-hearted and ruthless in its approach, doing whatever is necessary to attain its goals.
Since going on the run from the laboratory that created it, Epsilon has taken up a profession as a very skilled freelance bounty hunter and assassin. Although it prefers to utilise strategy and cunning use of its internal weaponry to defeat its opponents, it can also fight with deadly force.
Weaponry/Abilities-
- Specially-designed Wrist Cannons with a variety of different firing modes. These include Rapid armour-piercing shots that can fire at a maximum rate of approximately 7,000rpm, explosive grenade-like pockets of energy that can detonate with varying force (From about a Hand Grenade to a similar level as a Bunker Buster) constant light-like Beams for burning through multiple targets, and the ability to accumulate energy and release it in the form of bigger and more powerful Shots.
- Using a powerful Copy System, Epsilon has the ability to temporarily replicate the powers and abilities of others. By staring at them and scanning and copying their life data, Epsilon is capable of immediately and flawlessly copying other people's combat techniques, fighting moves and even superhuman abilities unique to specific individuals.
- Combination of an internal Anti-Gravity Device and thrusters in its feet allow it to hover and fly at high speed over short-to-medium distances.
Weaknesses
- Whilst in theory its Copy Ability does make his abilities potentially limitless, he has to deactivate his Wrist Cannons and scan his opponent before he can use their abilities due to limits with his power core, and he can only use one saved ability at a time.
- Its Wrist Cannons are powerful, but since they tap power directly from his core, he cannot use them too much in one go, and must take brief periods to cool down and recharge between firing. If he doesn't, he could potentially overload his core and destroy himself.
- Cannot fly as fast as it wants to within the atmosphere, since this will cause it to overheat from atmospheric friction.
