is it in an ice rink?
Its dam good though, well done on an impressive machine!
Karoline, luckily audience was behind 15mm polycarb/steel net at this event, bad thing was that roboteers didnt have that shield because it would have been too difficult to drive so far away. at next event audience doesnt have any shielding so i drop HCs rpm to 450. (and the weapon HAS a failsafe to prevent a runaway robot killing people)
JH-Q you have re-sparked my want to build a drum bot i have been drawing plans for ages and the result is .....Void.....
Ah I must have missed that bit on the video edit when you activated the failsafe, and removed the link before picking the robot up from the middle of the arena floor. BTW it was a very clear picture taken through the 10mm thick polycarb walls required for an arena to safely run spinners in the UK, but you are in Finland so perhaps it wasnt there.
BonX is ready
http://home.hccnet.nl/h.bouwens/Test1.avihttp://home.hccnet.nl/h.bouwens/Test1.avi
wow very good Tim , i really like the lighting Lol
got kang done for its event, here it is done -
http://photobucket.com/albums/v357/Cobrarobotics/Kang/?action=view¤t=DSC01449.jpghttp://photobucket.com/albums/v357/C...¤t=DSC01 449.jpg
and here it is after it got smashed in wouldnt you know it, the only weak spot...
http://photobucket.com/albums/v357/Cobrarobotics/Kang/?action=view¤t=DSC01456.jpghttp://photobucket.com/albums/v357/C...¤t=DSC01 456.jpg
that 10mm 5083 doesnt work too well :s
i ended up refitting it with an IBC too in the end.
Just finished rebuilding DragonStrike Dragon 2 and Tiamat. DragonStrike is the spinner the only diference is that the top and bottom is now 3cm thick high impact plastic instead of 6mm Ali. Dragon 2 is now 4wd with 18v drill motors. The bottom is 4mm Ali the top is 4mm polycarb and 1.2mm Ti. The sides and rear are 2cm Nylon the front is 2cm Nylon and 1cm Ti. Tiamat is a full pressure Flipper (courtesy of Mario). The side armour is 2cm Nylon the rear is Polypro.
Pics on profile.
Tony
All looking very nice - I love the new Dragonstrike paintjob
Ill join Ewan in that - looks fantastic Tony, most people are happy to have a box that moves - the dragon robots always look fantastic though !
Ed
