Re: 360 - mini hypnodisc
Try machining a correct aerofoil into a weapon... not going to be easy!
as for cooling- ill see how hot the motors get before acting... the lipo wont get above room temperature as its the same lipo i use in 360 which pulls way more current and it doesn't get warm.
Worst case scenario ill drill some holes in the armor above the motors to let heat out / let the blade blow over them.
Thanks Sam- its something Ive got to think about myself now lol Ive got an idea in the bag though... after our phone conversation i decided to just bite the bullet and go for a 40mm bearing mounted above the blade.
Removing it from the arena....
It will still be easy to lift it, but ill probably use a small crowbar/ screwdriver the lever it off the floor then slide some wood/plastic underneath to act as a cradle... as im a bit worried about dropping the front blade on my finger (will be very sharp) and having it pulled down onto the floor by the magnet....chopping of my finger.
Jesus, lol, how much does that thing weigh?
If I ever build a robot I sure as hell don't want to face that thing it looks too good.
not that heavy, 2.1kg
Looking at weights i think im going to have to have two shells... one made from hardox for when i want to run as a rammer and one made from titanium for when i run with the disc weapon.
First test drive, didnt get to full throttle as lipo wasnt secured lol ;
http://www.youtube.com/watch?v=iX5sUi61cJ8
looking good if i can get mine done soon we might be able to fight
540's looking good dude, its gonna have rapid acceleration when you've got the magnets in!
Looks like Mark has done grand job machining the bar. I like the care thats been taken chamfering the edges even round the middle section. I take it you have a decent 45deg chamfering cutter Mark? I had to set up the bridgeport head at 45 and use a normal end mill to chamfer the bar of NST, took a while setting it up 4 times.
Lol, thats at least the second time you've launched a lipo out of a robot in testing.... remember it happening with 360 too.
That is NIIIIIICE. It mesmerizes me as I watch it...
