Velociraptors Fanfic Tournament - Series 6!
Steve - 2
Overkill - zip :proud:
HEAT G
ROUND 3
REVENGE OF THE REVENGE OF THE BLUDGEONATOR VS Seggy the Third
Basic tactics here - slip around the side n rear and batter the shell a while (lets try and get a few potshots on those wheel guards :proud:). Once Ive got a few good blows in, Ill grapple on and feed it to either the Arena Disc or the Pit.
Go Richie! Go Richie! :proud:
Heat H is coming up, I can tell. Here are my tactics.
Dantomkia (me) Vs Mortis Vs Razer (31) Vs Tough as Nails
Keep away from TaN & Razer, flip Mortis OOTA & maybe pit either TaN or Razer. I gotta keep outta trouble in that fight
Tom, not to be rude, but do you have a memory problem or something? YOU CANT DOO OOTAS!
Oh yeah, well, pit Mortis & then pit of the other 2
I will be using the skirts and the scoop.
Get around the sides, underneath and push into arena disc, walls, pit.
So will the hammer or the interchangable weapons get through to the semis - Revenge Of Revenge Of The Bludgeonator or Seggy The Third (using a steel scoop with a flail)?
3, 2, 1 - ACTIVATE!
Seggy The Third had a faster start than ROTROTB, and turned faster as well, getting behind ROTROTB as it also turned, and then giving it a good shove! ROTROTB fired its hammer, but bounced itself into a sideways position on the scoop, and found itself against the north wall! Firing the hammer again, it whacked the steel scoop and left a dent in it, and bounced itself off! But before it could turn its front into Seggy, the other robot moved and got under its side, ramming it quickly into the pit corner so ROTROTB flew onto Seggys top! The hammer came flying down and bashed the top edge! Seggy quickly reversed and ROTROTB began sliding off, but it landed another hammer strike before it found itself on the scoop again! Pointing itself in the right direction, Seggy accelerated its prey towards the arena disc! Using its hammer to bounce again, ROTROTB went up and caused Seggy to run right past it! It chased Seggy, who stopped, then realised the situation and carried on going to outpace ROTROTB! Once at the south wall, it came charging back, missed another hammer hit and got to the side, proceeding to deliver ROTROTB to the disc and send it bouncing across the floor, on its side and rear! Seggy reversed towards it, hoping to overturn it, but ROTROTB had already landed on its back! The hammer selfrighted it quickly, but it ended up landing on Seggys scoop! Carrying ROTROTB more carefully this time, Seggy took it straight back to the arena disc!
ROTROTB entertainingly skimmed off again, with only scratched armour, but while it wasnt flipped, it did bounce, spinning like a frisbee! Seggy The Third came after it again, and caught it with its wheels off the ground, pinning it against another wall! The pin lasted a while, with ROTROTB firing its hammer twice and managing to shift itself onto the side of the scoop, forcing Seggy to drive it into a corner to keep a hold on it, and tilt it upwards using the wall. But when ROTROTB fired its hammer again, it came down on Seggys body again, and the hammer hit the scoop! A quick reverse from Seggy got ROTROTB off, so Seggy could pin it from behind again! Turning around, it began taking ROTROTB towards the pit release! ROTROTB fired the hammer again, but Seggy caught it as it bounced and carried on, shoving it hard against the release! As they turned towards the pit, ROTROTB tried its hammer once more, but was easily caught by Seggy and rushed into the pit, leaving Seggy The Third the second unseeded semifinalist!
CEASE!
SEGGY THE THIRD GOES THROUGH TO THE SEMI FINALS!
Next time on VFT6, 15th seed The Crashing Bore will show Constrictor, In-terror-fied and Storm 2 that age doesnt always mean weakness!
And 31st seed Razer will have an all-real-robot clash with Dantomkia, Mortis and Tough As Nails!
Nice performance from RotRotB there, I must say :)
HEAT H
ROUND 1
1) Constrictor VS In-Terror-Fired VS Storm 2 VS The Crashing Bore (15)
Storm batters Doms bot and the Bore bashes ITF up to win on a judges decision
2) Dantomkia VS Mortis VS Razer (31) VS Tough as Nails
Mortis gets sent 6 ft under thanks to DTK, while Razer crunches TAN up a bit and casts it into the abyss as well
Top stuff as always!
Not sure about what In-Terror-Fied is like, so Ill go for Constrictor first. Its got plenty of places I can get under safely, and a nice flat top, ideal for latching on to.
Whos controlling Storm 2? Im not suggesting a team up as such as an Ill leave you alone of you leave me alone pact :proud:
My heat will be after this one. And, seeing as everyone ELSE is going for Dominator 2, I might as well join in.
After that, I think Aaron and I should do a team-up on Disco Dancer (I do NOT want to attack Tengu and have ANOTHER bot torn to shreds).
