Slam the top in. Its lexan probably wont stand up to several whacks with the axe, itll have difficulty getting under the front, and my tyres are solid, so it wont be chewing those up. I want to whack it constantly, and just generally pwn.
Son of Ripper (2) vs. Megabite Rev 1.0
My tactics are to get rid of it as soon as possible, flipping it over should stun it so I can kill it off.
I predict a real robot heat final. Sorry AJ and Scott.
quote:
Running down corridors through,
Automatic doors
Got to get to you
Got to see this through
First night of your life
Curled up on your own
Looking at you now
You would never know
Heat E, Round 2
Fight 1
Tornado (31) vs. Glasgow Kiss
Tornado today is wearing the wedge with flail again.
3
2
1
ACTIVE
Tornado departs the leaving square as soon as active is called, as Matt accelerates his real robot up to speed, as Glasgow Kiss spins around to get it€™s axe into play, as the artful Tornado dodges around the front, as Scott turns to counter-act the attack, the European champion is underneath the side of the Scottish axe robot, and slams it full on into the sliding door.
Glasgow Kiss comes back down to earth, after bending the sliding door so that it can€™t slide back into place now. That is nothing, as once more Tornado slams into Glasgow Kiss which is gotten underneath and is slammed at full speed towards the arena hammer. Scott is trying to give his mark in the fight, but Tornado is proving to be too strong. One ram into the wall, the hammer comes down, another ram into the wall as Glasgow Kiss is rammed onto it€™s back.
Tornado quickly turns and forces the inverted Glasgow Kiss into the hammer, as the hammer comes down onto the underbelly once, twice and a third time, as Glasgow Kiss tries to self-right with the axe, but Tornado rams into it once more and takes Glasgow Kiss across the arena, ramming into the arena wall. Glasgow Kiss has damage, as co2 has started to leak from the insides, the shocks have knocked out the electrics in Scott€™s machine as it lies lifeless on it€™s back, the axe has no power.
The pit has opened as the lifeless form of Glasgow Kiss is pushed down 6 feet under and out of the competition.
Cease
In a cloud of smoke, Glasgow Kiss kisses it€™s last. Scott€™s robot didn€™t have any time to move to unleash the power. Tornado, powers into the heat final.
Fight 2
Son of Ripper 4 (2) vs. Megabite
What€™s worth waiting for? Let€™s go!
3
2
1
ACTIVE
The acceleration from the 2nd seed is great, as the two wheels come away from the starting square, as Megabite starts to rev up it€™s spinning shell. Look at the control off Son of Ripper 4, as it slams straight into Megabite and it is flipped over onto it€™s side. The Ziggo style self-righting bar on the American heavyweight champion self-rights it in no-time, but Son of Ripper 4 is on the controlling side for this battle and gets underneath Megabite once more and pushes it across the arena, Aaron is trying to remove Megabite away from Son of Ripper 4, but Andy is being the controller of this battle and is not allowing Megabite enough time to spin up it€™s shell.
The two robot party is coming over towards the arena wall, as Son of Ripper 4 quickly lines up and fires the flipper, sending Megabite sailing over the fence and straight into the arena camera.
Cease
In less than a minute, Megabite is flipped out of the arena. Son of Ripper 4 (2) moves into the heat final.
Heat Final Draw
Tornado (31) vs. Son of Ripper 4 (2)
Tactics, Predictions, did you like round 2?
See last post for set-up.
If Tornado is using the flail scoop, it will make my job a lot easier. I should be able to get under and toss the 31st seed over with little difficulty. After that I can go after the weak side plates with the bar and cause lots of damage while Tornado will be uneffective. Failing to cause damage, Ill try and toss it OOTA.
quote:
I get a need and Im wanting to please it
I got a face and Im wanting to feel it
The more I feel is the more that I need it
The more I need is the less I believe it
Heat E Final
It€™s an all-seed affair, in a repeat of a fight somewhere.
Son of Ripper 4(2) vs. Tornado (31)
In round 1, Son of Ripper 4 had a bye into round 2, whereas Tornado pushed Call out Hook into the pit
In round 2, Megabite Rev 1 was flipped out of the arena, whereas Glasgow Kiss was pitted.
Matt is keeping the same weapon once more for this fight.
3
2
1
ACTIVE
It€™s the turn of the low speed, high acceleration robots today, as both robots accelerate from the starting squares with healthy speed, as Son of Ripper 4 turns around to face Tornado. Matt turns the corner to avoid contact with the 2nd seed, as Andy follows Tornado, the 31st seed. The flipper fires on Son of Ripper 4, as Tornado is flipped onto it€™s back, by the faster Son of Ripper 4.
Pie and Chips Mrs Brown? Tornado moves around to counter-act the attack, as Son of Ripper 4 turns around to get his spinning weapon into play. Tornado rams at the rear of Son of Ripper 4, and manages to get the sharp edge to slip underneath the rear end of Son of Ripper 4 and slams the 2nd seed into the arena hammer. Once, twice and three times the hammer falls down onto Son of Ripper 4, but no damage is done.
Andy is free to be allowed out for free and comes back onto the attack, and manages to slam into the side of Tornado, sending it away without damage to the lexan. Tornado comes back onto the attack onto the flipper/disc combo, but in the last moment, Matt runs towards the arena spike, which fires, self-righting Tornado so that it€™s wedge is in play.
Son of Ripper 4 comes back onto the attack and rams underneath Tornado€™s sides and pushes the invertible box towards the arena wall. Quick as a flash, the flipper opens, sending Tornado on a spin, straight into the arena camera.
Cease
Result: Tornado, flipped out. Son of Ripper 4 moves one step closer to repeating it€™s famous journey.
Next time:
Heat G
Die Ceratops Invertus (13) vs. Deep Impact 2 vs. Shovearound 2
Flippa Frenzay Mk 6 (20) vs. Automatic Schmuck vs. Odyseus 2
Predictions. Tactics. Thoughts. Other.
Whoo, Shovearound 2s first fight with british stats :)
Anyawys, Ill do a tactic I do often when theres a spinner and another bot in the arena. Ill get under Die Ceratops Invertus, lift him, and ram him into Deep Impacts Discs. Hopefully deep impact dosent have any intensions of going after me, as Im scared of the discs and speed. Basically just RAM Dieceratops into deep impacts disc until he dies out.
Oh fook, shyte, and some pizz to go with that last fight. lol jk
All kidding aside, where can I find Automatic Schmuck and Odyseus 2s stats?
Try getting Deep Impact between myself and Shovearound. If he tries to push me, get off ASAP, and push back. Failing that, find a weak point for DI2 and, if thesable, flip OOTA.
