ok, fair try Ruark
the stats are VERY basic but cover most stuff
Ground Clearance: 1... 1 what? 1 metre, 1 fish, 1 green bottle on a wall?
Weakness: none... well, it lacks a srimech, thats a weakness for sure
ok, fair try Ruark
Joey 8,300 is realistic coz its a gas powered spinner umm Briggs & Stratton Briggs & Stratton World Formula go kart engine it the speed of the engine goes 8,300 rpms on 12v
Ah, didnt realise that because you said it was on 12v, led me to assume it was electric :P
But with a petrol engine, at least 20kgs worth of motors and batteries and a spinner, 10mm ti is probably a bit too thick - half that might be more realistic.
1mm all over the machine including rotors and weakness:lacks srimech
...and 1mm is way too thin :proud: try something like 5mm.
ok so im going to change my stats again guys sorry
Name: The Undertaker 2
Shape: Son of Whyahci
Armour: 5mm Titanium
Speed: 15MPH
Drive Motors: 4 S28-400 Magmotors driving 6 TW W238H-150-44H Wheel at 36volts
Weapon 1: 3 armed rotors with spiked sledgehammers spinning at 3,700RPM powered by a Briggs and stratton World Formula Go Kart Engine
Ground Clearance: 1mm all over the machine including rotors Strength: powerful weapon good armor and speed
Weakness: Lacks srimech
Hows that guys tell me wat u think
Ground Clearance: 5mm all ove the machine and 1mm on rotors
Srimechs arent mandatory. Typhoon 2 won series 7 without one, and beat a number of flippers en route to doing so.
joey check my stats again pls tell me if i got it right
Dont be sorry - at least your stats are improving each time you redo them, unlike certain people that could be mentioned :P
Looks at least in weight now, although having said that Im not sure how much the gokart engine weighs. Come to think of it, you havent said how much the robot weighs :proud: but theyre alright, if a bit lacking in detail.
Incidentally, since when was I considered a respectable arbiter of the accuracy of stats? :proud:
ok weakness on The Undertaker is none
guys check it out tellme if its right so i can fix it again if its not
I have 2 other vapours i will post them here after the Undertakers stat is correct
Hi Ruark:)
The robot looks fine to me now
well the weight of the undertaker is 200lbs so thats 100kg batteries are 2600 NiMh Drive Control Victor and the weight of the engine is 22lbs
dont know
cool so its ok now its not missing other details liam
100kg is 220lbs :P but that sounds about right.
i have 2 more stats guys if its ok with u guy i like for u guys to check it out before i put it on Zlaying Every Day Forum
Yeah, thats fine...if I recall, thats what this thread is sort of for :P
joey so my stats is ok or still needs some work can u pls tell me wat is missing:)
here is Ultimate killing machine
Class: Heavyweight
Weight: 100kg
Top Speed: 37MPH
Batterie 4 12v, 16Ah hawkers
Motors: 2 12 HP Briggs &Stratton ETEK€™s
Drive: Chain, 6 wheel drive
Steering: Tank
Weapon: Invertible lifting tusk powered by 2 motion actuator
Lift: 8€™@2 sec
Chassis: Titanium
Shape: Sewer Snake
tell me wat u think guys
Too fast to be really controllable, and from what Craig tells us Eteks really arent worthwhile for drive motors. Stick to Lem-130s, theyre also a lot lighter so you can use that extra weight to maybe bulk up the armour a little.
i think i got the second one right pls tell me
ok so here is my new stat
Class: Heavyweight
Weight: 100kg
Top Speed: 28MPH
Motors: Six Dustins, all set to 34v
Steering: Tank
Lift: 8€™@2 sec
Chassis: Titanium
Shape: Sewer Snake
here it is again ps check
can somebody tell me wat they think on Ultimate Killing machines stats pls
Again I suggest you use LEM-130s at 36v for the motors
Well for one thing you dont have any armour, and generally you just need more detail throughout:
Describe this lifting tusk describe the wheels, describe the chassis.
Also 12v batteries yet 36v power?
You also need ground clearnance, and while I presume lift is refers to the weapon you need to make it more clear.
A picture of some sort would help too.
Its pretty hard to guage effectiveness until you fix this stuff.
martijn can u do a CAD for The undertaker 1 the full stats is in Zlaying Every Day Forum
Hi there and welcome to the forum.
Jeez Ive only been away for a couple of hours and there is already a list a mile long. :)
Well lets look at your stats:
6 dustins to move a heavy is possible, but i doubt you will achieve 28mph on them. They will probably burn out way before then. On 36V you would get about 20mph on the 26cm wheels (I happen to use the same wheels as Sewer Snake in RCC2) And I wouldnt recommend going any higher.
34V is a really weird number to run motors on. 36V or 24V is pretty normal sometimes 48V (but thats not going to happen with Dustins),it usually goes in multiples of 6.
I dont see any mention of armour, so i would need that.
Id say its a work in progress. Keep it up.
Class: Heavyweight
Armor: 5mm Titaniun Weight: 100kg
Top Speed: 28MPH
Motors: 4 48v LEM130s, it uses 4 12 volt battlepacks, giving it about 48 volts total.
Steering: Tank
Weapon: Invertible lifting tusk powered by 2 220lb (100KG) motion actuator
Lift: 8€™@2 sec
Chassis: Titanium
Shape: Sewer Snake
true Frank, but lacking a srimech should be considered a weakness still :P
will do the CAD when I find the time
bout that guys check it out
Armour?
here guys my new version of The Undertaker
Class: Heavy Weight
Weight: 100kg
Top Speed:15 MPH
Batteries: 2600 NiMh
Drive Control: Victor
Weapon:2 20lb spinning disk with cutters
Weapon Speed: 3700RPM @72V
Weapon Motor: Etek-RT Motor Motivation: 6 NPC-PT444 10 inch flat proof wheels Strength: Powerful Spinner, good armor, speed
Weakness: none Self-Righter:2 low pressure Co2 powered bar on top of machine can self righted 30 time
2 incarnation of the undertaker pls tell me wat u guys think
Armour is 10mm titanium
so wat u guys think umm need more work
I dont think you need to state speed controllers *awaits inevitable backlash from Craig, Leo, etc. :P* and 10mm Ti with two Eteks and four Mags is overweight.
Armour: 6 Class: Heavy Weight
Weight: 100kg
Top Speed:15 MPH
Ive fix it i hope its right
I dont really state them in my specs but I do account for them in my designs. I dont really expect you to. Batteries is another matter.
Ruark: I need sizes of your robots too (length, width, height).
Lose the battlepacks in Ultimate Killing machine, 4 wont cut it and you already have Hawkers.
Undertaker is hugely overweight.
