But I dont have that. :proud:
LOL. :proud:
The fights will be shortly in after teh break!
So, here I go again. :)
From Team Turbine, Turbulence!
Turbulence is a former Roaming Robots Champion, with a flipper. It€™s got a tough shell with hardox and titanium, but it will run out of flips, and that will give Turbulence some turbulence. :proud:
From Team Chevron, Nidhogg!
This robot is brilliant. :proud: It€™s got a crusher, and lifting forks on the front, and it was runner up in Liam Eliot€™s €œROBOT SMASH!- Series 1€Â. However, that high ground clearence on the back doesn€™t look so good.
From Team Varying Every Day, With or Without You!
With or Without You is the 3rd clusterbot in this series, following Door Stops and Gemini. This dynamic duo is equipped with a scoop for the first half and a suicidal bar spinner for the other half. However, if the spinner€™s flipped, it€™s *plays Super Mario Bros. Game Over song*.
Roboteers, Stand By!
Booth 1: Turbulence, Nidhogg
Booth 2: With or Without You
3€¦ 2€¦ 1€¦ ACTIVATE!
With or Without You immediately seperates, and With You immediately goes off to find Turbulence. Turbulence immediately gets away, and now, Nidhogg comes into the action. It crashes into Turbulence, gets under, and down comes the crusher€¦ but not causing much damage, only a little hole. Now, Without You has spun up to full speed, and it crashes into Turbulence!
CRASH!!!!!!!!!!!!!
OH!!!! Turbulence has a small gash through the side, but€¦ OHMYGOD!!! Without You is in major peril himself, and€¦ HAHAHAHAHAHA!!!!!! Without You is going completely crazy! Heh€¦ that was unexpected€¦ Fortunately, Turbulence is okay, but Without You has self-destructed, and is onto its back. Oh dear... Now, With You scurries to help Without You, and rams it into the wall, uh€¦ onto its wheels, Martijn. Meanwhile, Turbulence and Nidhogg are still duking it out! But now, Nidhogg comes in again, and he gets a grip on Without You€™s tyres!!!! The tyres are getting crumpled! Martijn puts his controls down and makes an X with his arms, knowing he has been defeated. Turbulence comes in, and carries Without You over to a wall!!! Now Without You is launched 18 feet over and out of the arena! Shall we, Dave?
FA-LIP!!!
With You is still alive, but according to rules, if one part of a cluster goes out, then the robot itself is out. Therefore, With or Without You is out!
CEASE!
With or Without You breaks into a wrangled mess.
Turbulence and Nidhogg go through!
Here we go again. :)
From Team Insanity, Knocking Out!
Knocking Out has a devastating 8kg Terrorhurtz-style hammer, with spikes on it. However, it€™s armour is a bit weak, and it€™s easily flipped.
From Team Doomforall, Baldur!
Baldur has a lifting scoop for a weapon, powered by a set of pneumatics. It€™s also got tough front armour, but it€™s got no damaging weaponry.
From Team Unknown, Son of Ripper!
SoR has a very powerful flipping arm, and it has interchangable spinning weapons.
1. A saw blade
2. A vertical bar
3. A horizontal bar
However, it€™s invertible so maybe an axe or a crusher could easily crumple it.
SoR will be using the horizontal bar for this battle.
Booth 1: Knocking Out, Baldur
Booth 2: Son of Ripper
Baldur is already looking for SoR, and crashes into it! Now, it rams SoR into the wall!
WHAM!
Now, SoR has escaped and gets its blade spun up! It goes to find Knocking Out, and digs its blade in!
CRASH!!
OH!! Nice hit there by SoR, it sent the side skirt flying off! Now, SoR gets under the side of Knocking Out, and flips it!
FLIP!
WOAH! That sent the axebot 9 feet up in the air! Knocking Out self rights directly! Baldur is now looking for SoR again, but SoR comes in from the side€¦ and digs its deadly blade in!
CRASH!!!
OH!!!! There€™s a huge gash in Baldur€™s side! SoR comes in on Knocking Out, and Knocking Out tries to get its axe into play!
WHACK!
There€™s a not-too-visible dent in the armour, but that was just a minor damage. Now, SoR spins up again, and€¦
CRASH!!!
OH!!!!!! That€™s another very good hit by SoR, it ripped off a side skirt! Baldur gets underneath SoR, and slams it into the pit button, which I assume you know what it does. Now, SoR escapes, and slams its blade into THE SIDE OF KNOCKING OUT!!!!!
CRASH!!!!
OH!!!!! The 5mm titanium has a nice huge gash through it! Now, SoR starts pushing Knocking Out ever so closer to the pit, and€¦ Knocking Out is almost gone, and€¦ BOOM! Down it goes!
CEASE!
Knocking Out hasn€™t knocked anyone out.
Baldur and SoR go through!
Round 2 Lineups
Turbulence VS Baldur
Nidhogg VS SoR Hex
So, tactics, comments, predictions and a nice and warm chocolate chip cookie please.
It aint warm, but I have a choco-chip cookie regardless. :P
Turbulence vs. Baldur Gamma
Bad realie draw for Baldur. Turbulence to win via pitting or OOTA.
Nidhogg vs. Son of Ripper Hex
Could go either way, really, but SoR has the edge.
Tactics...read more of Samuels battles. :proud:
Booth 1: Turbulence
Booth 2: Baldur
Turbulence and Baldur, both teams very experienced. But Turbulence is immediately getting underneath the back ground clearence and€¦
FLIP!!
WOAH!! Turbulence launches Baldur 5 feet up into the air! Now, Turbulence comes in again... but Baldur lifts up Turbulence with its scoop and drags it into the corner where the saws are! BZZZT! The forecast calls for immense showers of sparks! :proud: Now, Turbulence is pushed into the pit release button, and guess what? The pit opens. :proud: Turbulence escapes, but is not interested in pitting Baldur, it wants to put Baldur out of the arena! Now, clearly avoiding that scoop, Turbulence gets under from Baldur€™s side and€¦
FLIP!
WOAH!! Turbulence flips Baldur almost over the fence! Now, just over 45 seconds gone into this fight. Turbulence gets lifted by Baldur and it goes towards the hammers!
WHAM!
WOAH!!! Turbulence gets a nasty hit by the hammers! Now, Turbulence just can€™t take this anymore, and gets underneath Baldur! Now it carries Baldur to the wall, and€¦ it€™s time to say good bye, Alex!
FA-LIP!!
CEASE!
Baldur has hit the camera tracks.
Turbulence goes through to the Heat J Final!
I think Ill write the next fight in 2 days. :)
Not to be rude, but...why? :S
Internet Problems... AGAIN!!! :angry::angry::angry::angry::angry::angry:
