Re: building a drum spinner
No as the voltage regulator would have to handle huge current surges. The simplest way to do it is to set the travel on your transmitter to 50% on the two channels that are used for drive. This way the motor only ever effectively sees 12v. What transmitter are you using?
i am using a dx6i transmitter, and i thought that the speed controler varied the current not the voltage to change the speed but i could be wrong? could i use a transformer imbetween the battries and the speed controler to turn the 24v into 18v? does this kind of transformer exist and would it be to heavy?
all the speed controller does is turn on and off very quickly to control the motor.
http://www.4qdtec.com/pwm-01.html
To put it simply, no, no it doesn't exist. Hook up the speed controller to your batteries. Change the travel adjust on the transmitter to 50 percent for the two channels you use for drive on the transmitter and the motors will only effectively see an average voltage of 12v.
Please note, that you should still respect the maximum limits that the sabretooth states overall.
This is the simplest method to run your motors on a lower voltage by tricking them into seeing the lower voltage. I have used this method several times myself and it doesn't require additional weight or parts in the robot.
How do I limit the travel of the gimbals on the transmitter
You don't. Check the manual for the transmitter and read the section on travel adjustment
How flat is the robo-challenge arena? Will 2-3mm ground clearance be enough? And how much do you think my new robo-challenge blue wheels will wear down?
The RC arena floor is pretty damn flat, so much so that ground-scraping wedges or flipper blades very rarely get stuck on the joins. 2mm-3mm should be fine (particularly if your robot is 4WD, but 2WD will still cope comfortably).
The blue wheels are pretty tough too. They will wear down over time (and by how much depends on how much pushing your robot does and how often it runs) but you could be looking at as much as a couple of years use, if not more, before they get so worn down that your ground clearance becomes an issue.
Where did you get the speed 900?
I got mine from Cornwall model boats
you can get them from smc
im guessing sussex model centre not the scottish med or mountaineering club!
im blind or i cant find the gear ratio!
I did originally order it from the Sussex model centre but there were long delays in getting it in from the manufacturer so instead I ordered it from cornwall model boats as they had it in stock and it arrived within 4 days!
As for the gear ratio I am using, I was planning on using a 2:1 ratio with normal pulleys but now have ordered timing pulleys instead with the same ratio. But the ratio depends on what voltage you run the motor at, I am running mine at 24v but my gear ratio is still very high so I may have to change it to 3:1 or 2.5:1.
I have already asked this on my build thread but might as well stick it up here as well, is the name invictus taken?
