Gradually welded to avoid distortion. Worked this time!
Both shoulders complete and in position
Second arm bent and ready to be welded
Arm end plates welded on
Both arms all welded. Predator looks great from this angle!
Turning the bearing mount for the head in the lathe
Bearing hole almost finished
Bearing plate with part of the cradle attached
Front of bearing plate drilled and taped ready to be bolted on
Almost finished with bearing pressed in.
Bearing plate and cradle in position. Starting to take shape!
Arm claws are cut out in the band saw
left claw folded into shape
Weeks of filing needed to smooth down the welds on each arm.
Back plate armour made from 0.6mm titanium
Backplate armour shaped and bolted on
The underbelly made from 0.6mm titanium
Rear armour plates shaped from 0.6mm titanium go under the shoulders.
Dowels are drilled and taped to fit the rear armour panels
More machining done to the head bearing mount to reduce weight.
Two holes bored out for 2 astroflight motors. I think I will only use one and machine a new bearing mount now though
Hand turned dome head made by my dad for my 21st birthday. Its perfect!!!
Finished bearing mount in position and head attached to check the fit.
Machining holes in to bolt the drive gear to the underside
James, this looks incredible!
Thank you very much Kane! really appreciatedQuote:
Originally Posted by kane
Second that, looks pretty amazing, enjoying the photos.
Are you going to fight with it? You'll have the bizarre advantage of no one wanting to scratch your machine, let alone damage it!
The original plan was to demo it.... but it wouldnt be the same so its being built for full combat which sometimes makes me cry lol.
Was really hoping to have it ready for the champs but that doesnt look likely :(
holes are being drilled into the dome at an angle
All holes complete
M3 holes tapped into the top to bolt the top cap on
The head is on the rotary table which has been angled to machine the flutes in the top
First one done! I remember being really pleased with it!
3 more done looking good!
Predators head complete. Looking beautiful
Machining being done to the heads drive gear
Custom made titanium bolts for the head cradle in position
Nylon rollers and brackets mad an in position
Original drawing for the head cap and the block of ali ready to make it!
The rear face gets turned first
