I just got bored :proud:
It gets bigger. :)
Though I daresay its always open for more people. :wink:
Ymean I could register?
*Hint hint*
If you wanted to...
How do I start a forum to put my stats in?
Ill contact you on that forum via PM, we dont speak of it here and waste posts. :)
Mint-flavoured Tictacs:
Paul has in his control a very well-designed machine, and theres no way 1 tonne of crush will come close to breaching a 5mm hardox monocoque shell, or 6mm flipper arm for that matter. I am as surprised as Paul that my machine has come this far, but hopefully it can go that extra yard and claim the victory!
Nitro-Gene will be able to outpush me in a head-on joust, 4WD LEM-powered drive vs 2WD Bosch motor drive - heck, I wouldnt even bet on me winning that one. But Pauls traction and pushing power is only effective when the wheels are in contact with the ground :)
If I can somehow get a grip on Nitro-Genes chassis, the chances are itll have ridden up my little front wedge in the process, breaking its traction with the arena floor. All I then need to do is to make sure I hold on to Nitro-Gene and drag him, via a certain button, to the pit of oblivion. All of this I will aim to do as quickly as possible. For a final fight it may not look pretty but its the win that matters - putting on a show only comes second :)
Best of luck Paul, and may the best robot win!
Jamie, can I point out that Nitro-Genes rear is designed like Tornados so if it drives onto a wedge it still has wheels touching the ground.
And in my opinion, I dislike it when finals are short, even though that never happens in fan-fiction, at live-events it slightly disappointing to have a quick final.
It depends on ground clearance, Paul, and the length between the (rear) wheels and the rear end. :)
Thats assuming you drive on to me front-first Paul - there are still three other sides on your robot :)
And while they may have skirts, they cant possibly be effective for 100% of the match. At some point one of them will bounce up off of something, and thats when Ill aim to strike! :proud:
(or at least, I can TRY to do that - whether it actually works is a different matter :S)
And even hinges dont work sometimes. :proud:
Play-Off
Namies Style v The Alexandra Sisters
Booth 1: Chezza
Booth 2: Kody Kunz
3...
2...
1...
ACTIVATE!
The sisters quickly split up, and Cassandra presses the pit release while Sophitia lines up for an attack on Namie! Chezza warily goes out into the center of the arena, then decides to try and ram Sophitia! But Cassandra comes in from the side, throwing Namies Style onto its back and pushing Chezza into Sophitia, who gets underneath and pushes Chezza around! But with the flipper on the wedge Chezza easily self-rights and pushes underneath Cassnadra, throwing her up into the air with the flipper and giving her a massive headache! Kody quickly self-rights and Sophitia comes in from behind Namies Style, flipping Chezza onto his back again! Namie quickly drives away from the dangerous clusterbot, but he is pursued by Cassandra, who rams him into the angle grinder! Namie pushes her away, and in comes Sophitia getting underneath the front wedge and pushing Namies Style towards the pit! But once more Namie self-rights off Kody and gets underneath Cassandra, this time pushing her around in a wide circle before he flips her over and pushes her into the pit! AMazing, what a turn around!!!!!!!!!!!!!!!!
And now Sophitia is out as well, but for the hell of it she runs in on the attack and nudges the celebrating Namies Style into the pit of obilvion to signal a second puff of smoke! Nevertheless Namies Style gets third, though Chezza neednt worry as Kody decides to have some more fun and Sophitia chases the refbot and throws him over! Then Kody pushes the refbot head first into the pit, then looks around with a wild grin and plunges in after the ref!!!!!!!!!!!
CEASE!
A very peculiar battle indeed, but Namies Style gets third place!
Coming Next-the final!
Nitro-Gene 4.0 v Dr. Acula
Final:
Dr. Acula v Nitro-Gene 4.0
Let€™s see look back on this tournament and see how these two manic masters of mayhem got this far:
They were in the same round one melee, and Symmetry€™s batteries ran out of power to eliminate Leo Van Miert. Then the fight went to a judge€™s decision to determine who would prevail from the remaining three robots, and Minesweeper was eliminated.
In the first semi-final Namie€™s Style took damage from the claws of Dr. Acula and was eliminated while in the second The Alexandra Sisters proved to be too lightweight and were flipped out of the competition.
Booth 1: Jamie McHarg
Booth 2: Paul Cuomo
3...
2...
1...
ACTIVATE!
And we€™re off to a very quick start, Nitro-Gene seems very aggressive, homing in on Acula, but the doctor is ready and twists around in an attempt to get the wedge underneath Nitro-Gene€™s skirts! But for now they hold up and Nitro-Gene gets underneath the side of the component pod on Dr. Acula and throws it into the air! Dr. Acula cartwheels sideways, but lands the right way up and chases Nitro-Gene again, this time succeeding in getting under the skirts and grabbing the side with the claws! And now Jamie rams Nitro-Gene 4.0 into the pit release tyre, signalling the lowering of the pit and the wailing of the siren that alerts the crowd of the pit-lowering!
PIT, PIT, PIT, PIT, PIT, PIT, PIT, PIT, PIT, PIT, PIT, PIT, PIT, PIT, PIT, PIT, PIT, PIT!
They want to see that puff of smoke and Jamie does too, but Paul fires the flipper and loosens Acula€™s grip just enough for Paul to escape! The crowd roar with surprise as Nitro races away, the turns to come back on the attack and stacks Dr. Acula on the arena side wall! And now Paul comes in to finish the job with one almighty flip- but he knocks Jamie off the wall when he comes in and Dr. Acula escapes, only to turn around quickly and grab Nitro-Gene from behind! And once again Jamie is in control it seems, but Nitro€™s front wheels are still on the ground and Paul pulls Dr. Acula towards the chasm! Jamie does the sensible thing and let€™s go, but it could be a mistake even if Acula had gone into the pit because now Nitro-Gene comes on another onslaught and throws Dr. Acula over and over again, Jamie€™s machine bouncing noisily across the floor and finally coming to land in the corner! But now Dr. Acula is upside down and when Paul attacks again he doesn€™t flip Jamie back over, but rams him around, especially into the angle grinders! Jamie desperately tries to get away, but Paul is persistent and keeps pushing Dr. Acula back into the wall, until finally Dr. Acula gets beached on Nitro€™s wedge and Paul heads towards the pit! The crowd goes wild with excitement- is this the end of the bout? No, it would seem, as Dr. Acula simply refuses to slide off Nitro-Gene€™s wedge when Paul gets to the pit! And the only way Paul could get Dr. Acula in would be driving in himself, and he may hit the bottom first and lose, so he€™s not going to try it! But what he does try is use the flipper to punt Dr. Acula up into the air and in, but too much power and Jamie flies right across the pit and lands the right way up, before he comes back on the attack and grabs hold of Nitro-Gene€™s raised flipper arm! But now it seems that wasn€™t such a good idea, as Paul drives to the pit and dangles Dr. Acula over the side! If Jamie lets go he€™s toast, but time is ticking down and those claws are losing purchase on Nitro-Gene!
10... 9...
Dr. Acula slips very slightly...
8... 7... 6... 5... 4... 3...
And now one claw slips and let€™s go completely, so Dr. Acula is hanging onto dear life with just one claw!
2... 1...
Dr. Acula slips off!
CEASE!
Dr. Acula may have slipped, but it didn€™t hit the pit until after CEASE was called! We now have to go to a judge€™s decision!
Judge 1:
Damage: Dr. Acula- 18pts, Nitro-Gene 4.0- 12pts
Aggression: Dr. Acula- 5pts, Nitro-Gene 4.0- 20pts
Control: Dr. Acula- 14pts, Nitro-Gene 4.0- 6pts
Dominance: Dr. Acula- 6pts, Nitro-Gene 4.0- 9pts
Style: Dr. Acula- 4pts, Nitro-Gene 4.0- 1pt
Overall Judge 1: Dr. Acula- 47pts, Nitro-Gene 4.0- 48pts
Judge 2:
Damage: Dr. Acula- 20pts, Nitro-Gene 4.0- 10pts
Aggression: Dr. Acula- 12pts, Nitro-Gene- 13pts
Control: Dr. Acula- 12pts, Nitro-Gene 4.0- 8pts
Dominance: Dr. Acula- 4pts, Nitro-Gene 4.0- 11pts
Overall Judge 2: Dr. Acula- 52pts, Nitro-Gene 4.0- 43pts
Judge 3:
Damage: Dr. Acula- 16pts, Nitro-Gene 4.0- 14pts
Aggression: Dr. Acula- 4pts, Nitro-Gene 4.0- 21pts
Control: Dr. Acula- 16pts, Nitro-Gene 4.0- 4pts
Dominance: Dr. Acula- 3pts, Nitro-Gene 4.0- 12pts
Overall Judge 3: Dr. Acula- 43pts, Nitro-Gene 4.0- 52pts
Overall Judges Decision:
Dr. Acula- 142pts, Nitro-Gene 4.0- 143pts
By a single point Nitro-Gene 4.0 is the winner of the Mini-Tournament!
And I swear guys, when I was writing the scores for the JD I didn€™t intend for it to add up to a 1pt difference, it just did!
Goodbyeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeee!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!
Very good fights Liam, and congratulations to Paul - winner by one point in what is the most overly complicated judges decision I have ever seen :P
Paul finally wins something. :proud:
Congratulations Paul :)
Good final battle Liam - one point in it though, damn! :P
Ah well, one of the first tournaments (albeit just a mini tourney) that I entered which I come away with second place in; cant be too upset about that :)
Also I forgot to note how pleasantly shocked (and slightly p***** :proud:) I am, losing to Namies Style. :talker:
Oh my! *blushes* Didnt expect to win against the Greek sisters.
Well clusterbots generally suck. :lame:
With the possible exception of Door Stops. :proud:
Great Job, Paul!
You certainly have one heck of a robot!
*applauds*
Sorry for this rather late, and overly happy response, but my internet has been down for days, and I wont get proper access to respond until Friday, or maybe Thrusday if lucky, but...
+2>WOOOOOOOOOOOOT!
Brilliant fight Liam, and brilliant performance from Jamie. And also, well done to everyone who lost :mrgreen: and took part at the same time. Nitro-Genes first trophy - the only way is up...or down, but Ill prefer it to be up :proud:
