The Outsiders Cup
Normally I would have said something, but seeing Matty post that above, just took the words right out of my mouth. Shame that you were Matty, really. :sad:
I will add this though, Paul. There ARE things that are called delays that vary in situations and time periods. Dont get all bent out of shape just because of a larger-than-usual delay like Mattys. In short, CONTROL YOURSELF. :lame:
The Outsiders Cup
quote:
AVARICE
Shape: I was thinking Slam Job with the middle cut-off, but I decided to go for a Tornado with more of a rounded front end. There is a small front scoop there to defend against wedge attacks, and the usual titanium skirting on the sides and rear.
Colour: Dark orange. Axe head is red.
Weight: 100kg
Speed: 7mph, its not meant to be really fast, but its geared to acceleration.
Drive: 4 S28-150 Magmotors, run at 36v. Very light and still give off pretty good power, especially when there are four of them. :-)
Power: 8 CP2400R NiCad Battlepacks, 36v, 2 for each of the MagMotors.
Motivation: Now, this is one of two things that makes this bot unique. It uses Omni-directional drive, exactly like BB middleweight Root Canal; it is 4WD, but instead of tires it uses rollers, with a very thin layer of vulkalon put on them for reassuring but not too reassuring grip on the arena floor. This will allow Avarice to not only go forward, backward, or spin around, but also go diagonally, or strafe from side to side, completely avoiding opposing attackers. Each of the S28s powers a wheel, giving it a good boost of power. Using rollers means it sacrifices speed and traction but thats okay for the huge amount of maneouverability Im gaining.
Armour: 5mm 6063 aircraft aluminum on the top and bottom, and there is 9mm HDPE on the sides.
Ground Clearance: 0mm at the scoop and skirts, and without them its 4mm.
Turning Circle: Absolutely positively 100% ZERO turning circle!!! :-O
Dimensions in CM: Unknown, trying to get a CAD of it done...
Weaponry: Heheh...this is the other half that makes this bot unique: a 360 double-sided axe. It is like Terrorhurtzs axe, except it has a longer reach, and the head is different: it starts like an axe at the bottom of the head then broadens and becomes like a hammer, meaning when it comes down it will split armour and then make it the hole wider, and it is like that on both sides. What it makes it a rotating axe is a turret ala Tazbot, controlled independently with its own turn motor and speed controller. It rotates not only the axe but the pneumatics and rack-and-pinion mechanism inside. The axe itself is powered by 2 2.5kg CO2 bottles, which should provide enough power to serious hurt some armours, and its got about 30 shots. Not only that, but it has small hardox spikes on the side of the head; being an omnibot, Avarice can spin REALLY fast and so if the axe runs out of CO2 it can act as a thwackbot, and bludgeon some armours with those spikes. If the turret is working, it can also spin the axe making it go even faster, and damage armours even further...
Srimech: Axe.
Strengths: Maneouverability is crazy, extremely versatile and damaging weapon, good acceleration. Unique design.
Weaknesses: Poor armour, limited CO2, cant right itself when axe malfunctions, crappy top speed. No picture yet. (but I WILL get a CAD of it done soon!)
Nice work Kody, youve put some thought into that design. Although I think you could probably just squeeze in a bit of Hardox armour pending on the weight of other things, it looks pretty good. The S28-150s will probably suit the omni fairly well since they wont be loaded up too much with the omni drive, and will be spreading the load of 4 of them.
Im interested to see the CAD, seems like a interesting design. Although, since its omni directional, Id ditch the turret idea, it will be easier to spin on the spot pretty quick and run sideways to hit an opponent if you need to. The save weight over a turret system will allow for Hardox armour :proud:
The Outsiders Cup
Hmmm...
You are probably right about that Aaron. Stat change coming when I can get a CAD of it done. :proud:
The Outsiders Cup
Not forcing you into changing your designs Kody, but looking at other robots with turret based weapons, they use them because they have poor manuverability. Gammatron and Pressure Drop come to mind. Although, other bots like Tazbot are the complete opposite :proud:
The Outsiders Cup
No, really, I just noticed you had a very good point, as a faster spin isnt really worth the poor armour. :proud:
Thanks for the advice. :proud:
The Outsiders Cup
You can always survive with no weapon, but you cant survive with no armour :proud:
The Outsiders Cup
You know, I was going to try and CAD the inside of the robot but thats way beyond me. :proud:
Just going to do an exterior CAD, nothing special. Should have it up in a moment...
The Outsiders Cup
ALL RIGHT!!! I have the CAD up. Revised stats too.
Avarice
Shape: Box with sloped/rounded front end. There is a scoop at the front, flanked by smaller front skirts. Also, side and rear skirts hinged in the middle will help against wedge/flipper attacks.
Colour: Dark orange with red axe head.
Weight: 100kg
Speed: 8mph
Drive: 4 S28-150 Magmotors, run at 36v. Very light and still give off pretty good power, especially when there are four of them. :)
Motivation: It uses Omni-directional drive, exactly like BB middleweight Root Canal; it is 4WD, but instead of tires it uses rollers, with a very thin layer of vulkalon put on them for reassuring but not too reassuring grip on the arena floor. This will allow Avarice to not only go forward, backward, or spin around, but also go diagonally, or strafe from side to side, completely avoiding opposing attackers. Each of the S28s powers a wheel, giving it a good boost of power. Using rollers means it sacrifices speed and traction but thats okay for the huge amount of maneouverability Im gaining.
Armour: 5mm hardox 600
Ground Clearance: 0mm at the scoop and skirts, and without them its 6mm.
Turning Circle: Absolutely positively 100% ZERO turning circle!!! :proud:
Dimensions in CM: 97 x 91 x 29 (main body)
Weaponry: A giant, full-pressure, pneumatic axe shaped more like a hammer, powered by two 2.5kg CO2 bottle. It moves rack-and-pinion style like Terrorhurtz. The axe head itself is titanium, and diamond-edged. It can damage even stronger armours like titanium and hardox.
Srimech: Axe.
Strengths: Maneouverability is crazy, extremely damaging weapon, good acceleration, good armour. Unique design.
Weaknesses: Limited CO2, cant right itself when axe malfunctions, crappy top speed.
Picture: http://img2.putfile.com/main/12/35514463188.jpghttp://img2.putfile.com/main/12/35514463188.jpg
The Outsiders Cup
Awesome picture Kody! :proud:
The Outsiders Cup
I just wanted to post in to revive this thread for everyones benefit, and also to ask Steven if hed like to put some of his robots forwards for my E.O.T.R Series 3 competition.
The Outsiders Cup
Recruitment of vapours for your own tournament is best kept inside your own tournament Paul, ESPECIALLY when that tournament is only 1 day old. If you have problems filling your spots (and nobody gets 12 spots filled within 1 day), e-mail is a great option.
Other than that, Steve seemingly has his spots filled if Im right, cant wait for this thing to start!
The Outsiders Cup
He has ALMOST all his spots filled in - Matty needs his vapourbot sent in, and then we can get going!
The Outsiders Cup
Sorry to do this again, Steve, but...switch Avarice back to Seung Mina...only make it Seung Mina III this time. :proud:
Stats http://strickenone.proboards99.com/index.cgi?board=heavies&action=display&thread=1145 111759http://strickenone.proboards99.com/i...display&thread =1145111759
The Outsiders Cup
Kody in a quick look at your stats you dont actualy indicate clearly whether the flipper is front or rear hinged.
The Outsiders Cup
There, I edited it. That better for ya? :P
Hahaha, just kidding. Thanks for finding that Martyn.
The Outsiders Cup
I think Ill change the current Nitro-Gene model and enter the secondary version:
Here we are:
NITRO-GENE 2.0
€ WEIGHT: 100kg
€ ARMOUR: 4mm Hardox for the body. Holes are drilled into the slanted sides to allow for a 6mm Hardox flipper
€ SHAPE: Low invertible box with pointed sides and rear. At the front is a Storm 2 style wedge to end in getting underneath other robots.
€ MOTORS: 4 x LEM 130€™s at 36V = 36HP
€ LOCOMOTION: 6 Vulkanised Wheels.
€ DIMENSIONS: (L) 80CM (H) 16CM (W) 60CM
€ COLOUR: Black all over with the flipper coloured red.
€ WEAPONRY: A full pressure Nitrogen powered flipper at 1000psi, using a single 80mm ram at 1000psi. The flipper is mounted in the middle of the robot, and is 20cm wide and runs 30cm up the body. Using a 3cm long Titanium strip underneath the flipper, and a heavy flipping arm, the flipper runs completely along the ground. Running on a reverse ratio, the flipper produces 1500kg of force at the tips, allowing me to launch anyone away.
€ SPEED: 19mph
€ GROUND CLEARANCE: 0MM-2CM. At the front, it is completely 0mm. On the unskirted sides/rear, its 2cm.
€ STRENGTH: Pushing power and weaponry.
€ WEAKNESS: High side/rear ground clearance
