quote:
I dont enter anything I havent rendered.
Well I guess you cant enter, then. :rofl: Rules state you need at least one realie.
Never said I wouldnt render a realie. Ive done it before.
http://www.deviantart.com/deviation/31586008/?qo=13&q=by%3Amental-rectangle&qh=sort%3Atime+-in%3Ascrapshttp://www.deviantart.com/deviation/...rectangle&qh=s ort%3Atime+-in%3Ascraps
Unfortunately, this ones in the wrong weight class.
(Message edited by parassyte on April 16, 2007)
:lol: Ya got me, but Ill be back!
Okay, Im back. Whats new? :proud:
Can I enter? I do not spam anymore and heres one of my robots.
Robot Name:Flippatron
Weight: 99kgs.
Weaponry: a flipper which feeds off 3 36v batteries and 2 co2 canisters which should toss about 100kgs. This is also the srimech
Movement: 2 wheels which is run on 2 darkfusion batteries (I think thats what theyre called) each which should drive at 15mph even though it s top speed is 23mph it cant run for long on 23mph so it must run 15mph.
Team Name: Team Karma
Vapourboteer Name: Tim Sillery
Dimensions: 180X80X210
Shape: A Box like robot.
Ground Clearence: 15mm
Strengths: Can toss any robots, quick and easy to attack.
Weaknesses: Easy to get under, sometimes unreliable.
Timmy, you robot is a flipper and under the flipper is 15mm gc, so it wont get underanything
...hes back.
Okay Tim, some pointers...
1. EIGHT VAPOURBOTS/ROBOTS. EIGHT. Jeez...
2. Some errors with your stats:
Is your flipper front or rear hinged? You dont need batteries for a flkipper, either. Also, 2 CO2 canisters should toss more than 100kgs, I do think...
What are the wheels made of, Vulkalon rubber? Are they based off of a realie? You dont have to babble on about speeds, though: just say its top speed is 23mph and its average speed is 15mph.
Impossible. Unless your robot is made of cardboard. And Ill assume that since you dont give any armour stats. :proud: Either shorten the dimensions and get some armour or expect a serious loss. That is, if I allow you to enter that.
Youre going to have a hell of a hard time getting under robots with 15mm all around, as Martyn said. Make the ground clearance shorter, say, 5mm or something, and make the front flippers clearance 0.
Just some friendly vapour advice. :proud:
another pointer...
the tournaments full...
Well Martijn, maybe not, because some people *cough*CHRISCALEXMWAJ*cough* dont have bots in at all. =P
People who have all their bots in
Steven McGregor
Christopher Mason
Frank Goacher
David Sheppard
Anthony Politzi
Alex Holt
People who have some bots in
Martijn M Benschop (need one)
Aaron Knight (need one)
Martyn Forsyth (need seven; only has realie =P)
People who dont have any bots in yet
Chris Cooper
Andrew Jackson
Alex MacWilliams
Therefore, Matty, Tim, and Nick, you are welcome to enter 8 robots/vapourbots, and if you do, then youll take a space from either Chris, AJ, or Alex MW.
Okay soz the ground clearence I forgot to say was the back and the sides because the front has a wedge extender to make it 0mm ground clearence. ok if you say so then you say how much 2 CO2 canisters can toss and thats how much it can toss and the flipper is Chaos 2 and Gravitys type of flipper. Dimensions 60X35X80mm and the armour is 5 mm bulletproof plastic ( If there is such thing) If there isnt then 5mm titanium.
Real robots:
Gravity
Wheely Big Cheese
Chaos 2
Pussycat
Bigger Brother
St Agro
Bulldog Breed 3.
More flaming to do...
No, no, NO. Youre the one whos supposed to come up with a reasonable value, and if you cant do that then you shouldnt partake in these things.
Again, youre making unrealistic values, Tim. You need to do research before you ever try making robots. Buy some robot books or find some good sites, PLEASE. Otherwise dont come here.
Im not accepting your entry until you do some major improvements.
OK it can lift 200kgs and it can toss 120kgs and I meant CMs not MMS.
Someone correct me if Im wrong, but I dont think canisters affect flipping power, just how many flips you have.
OK I have about 50 flips and can I have Typhoon 2 and Drillzilla instead of the 2 already taken please.
Timmy if you ment cm insted of MM then your robot is 1.8mMETERS X 80cm X 2.1METERS. Which anyone can correct me if i am wrong seams a little bit huge for a robot
And Chaos 2 and Gravity have 2 totaly different flipper systems.
Oh and Kody, you do need batteries for a flipper. The valves dont work otherwise.
Oh my god...
Here we go again...
Okay, people, just ignore Tim. Well continue like nothing happened.
N33D B0T5 PLZ. THX.
For the sake of you writing a battle with a vapourbot powered by darkfusion batteries, my entries will be in some time over the weekend. Is there any chance someone can provide a list of real robots entered so far please? Im too lazy.
3x 36v batteries arent needed for a flipper mechanism IMO, but correct me if Im wrong. Darkfusion batteries? Again correct me if Im wrong but Im pretty sure they dont exist. Just reference SLA/NiCad/NiMH and get it over with. For the rest see what everyone else said. And stop randomly guessing values for your system - if you havent calculated the true force of the system then dont state it! The flipper has gone from flipping 100kgs to 120kgs to 200kgs with very little change from what I can see.
At least hes trying this time... :lame:
No it can lift 200kgs and it can toss 120kgs and the batteries are NiCad batteries then and the flippers front hinged is what I meant. Its now 80cmX80cmX1.2m. Is that alright.
I will get you stats when I find them in my virusfull computer :lame:.
What real robot(s) have i entered and how many more entries do i need??
Erhem, real robots that have been taken are...
Disc-O-Inferno [Extreme 1] (Christopher)
Big Nipper [S7] (Dave)
Storm 2 [S7] (Dave)
X-Terminator [S7] (Dave)
Kan-Opener [S7] (Dave)
Chaos 2 [Extreme 2] (Steve)
Spawn Again [S7] (Anthony)
Wheely Big Cheese [S5] (Alex)
Megabyte (Aaron)
Warrior SKF (Aaron)
Turbulence (Frank)
Tough as Nails (Martijn)
Terrorhurtz [S6] (Martyn)
Panic Attack [Extreme 2] (Martyn)
NAME- Mousey 4
SHAPE- Shaped like a mouse with a sort of like front wedge, formed by what would be the mouse€™s face/nose
COLOR- blue, well the fur is, the armour is silver.
WEIGHT- 100kg
SPEED- 13mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- 0mm at the front 6mm for the rest
ARMOUR- 5mm grade 5 titanium over that is 3mm fur, which extends over the back to form a tail
WHEELS- 4 inner wheels, like those on storm 2
POWER- s28-400 on 24volts
WEAPONS- flipper on the wedge which self rights the robot
NOTES- covered in blue fur and has two fire storm style flippers to get it off the wall if flipped on wall
STRENGTHS- good armour under fur, fur can jam discs
WEAKNESSES- Limited CO2, it€™s a mouse
Shape: Low Wedge with small rear wedge
Motivation: it now uses four storm 2 style Vulcalon wheels
Speed: 12.5 Mph
Weight: 100kg
Height: 300mm to top of body, 600mm to the top of the disc
Length: 1300mm
Width: 600mm
Weapon: 500mm Vert. flywheel @ 3000rpm. Has a 4.00 second spin up time due to the C40-500 Magmotor on 36v with a 2:1 twin tension cog belt reduction. The flywheel produces 31.5Kj€™s at maximum RPM but is lethal at around 1 second. The second weapon is also the srimech, this weapon is a low pressure pneumatic flipper running on 10Bar (145psi) running into a single 80mm bore ram. This produces 509kg at the ram and is then transferred into the flipper with a leverage point ratio of 1:1. This is a forward facing flipper like FireStorm and will have no problem toppling the heaviest of robots.
Chassis: 4mm Grade 5 Titanium monocoque with extra 5mm Titanium ribs to give it more rigidity.
Drive: 2 x S28-400 Magmotors @ 36v with a 10:1 Mod 2 spur gear reduction
Batteries: 90 x 3000mAh NiCD cells producing 36v @ 9amp
Color- the robot and skirts and flipper are blue and the disc is yellow
Clearance- it has 0mm at the front due to the wedge it has 0mm at the sides due to skirts its 6mm with out it also has a 0mm at the rear due to the small wedge which is there to replace the problem of the skirt being flipped into the disc. The skirts are NOT hinged and held down by torsion-springs so they shouldn€™t spring up and the rear one shouldn€™t go up into the disc
Notes- The flywheel is at the back off the robot it goes over the back of the wedge so if I can get a robot up the wedge far enough it will be hit by the disc. The skirts stop the robot landing on its side.
NAME- The deer (was crusher chaos)
SHAPE- Invertible box
COLOR- the robot and claws are a dark green color
WEIGHT- 100kg
DIMENSIONS- 1m x 80cm x 25cm (l,w,h)
SPEED- 15mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- It has 6mm at the front due to the claws and has 0mm at the sides and rear due to the skirts, without skirts 6mm. The skirts also work both ways up.
ARMOUR- 3.6mm hardox
MOVEMENT- 4 inner wheels that make the robot invertible
POWER- 2 x S28 Magmotors on 24v.
WEAPONS- it has a front pair of horizontal hydraulic crushing claws set up like deers antlers (shaped like those you find in extreme destruction.) The claws have 3.5 tones of crushing force on the front tips of the claws at the middle is 6tones and right at the back it has 8 tones of crush. The claws are powered by hydraulics through a 120mm bore rams at 3000psi
NOTES- invertible, wide base means the deer wont topple while crushing
STRENGTHS- Very powerful weapon
WEAKNESSES- it could be turned into venison
NAME- Star 69
SHAPE- It€™s a shaped like a five point star but the points are mounted round a inner circle so the points of the star spin round
COLOR- yellow
WEIGHT- 100kg
SPEED- 19mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- about 9mm but is lower under the bottom teeth where it is about 3-4mm
ARMOUR- it has 4mm grade 5 titanium
MOVEMENT- it uses 6 inner storm 2 wheels
DRIVE- it uses 2 x lem 130€™s
BATTERIES- 4 x 30 cell 36volt 3ah Sanyo NiCad packs
WEAPONS- as I said it has an outer spinning ring so is a fbs the ring is powered by a C40-500 Magmotor, the points on the star each have sharpened teeth on them and it spins in a clockwise direction, each point has 3 teeth on it, one on the bottom for tearing at skirts in wheels, one in the middle for body work and that, and one at the top for aerials and tall robots.
SRIMECH- Invertible, points and blades stop it from sticking on side
NOTES- according to frank the name is rude, first star shaped robot
STRENGTHS- Powerful weapon and drive
WEAKNESSES- people not wanting to call it back?
Name- Panicking
SHAPE- Low invertible box
COLOUR- Yellow except for the lifting forks which are black
WEIGHT- 98kg
DIMENSIONS- 65cm x 60cm x 15cm (Length x Width x Height)
SPEED- 23mph
TURNING CIRCLE- 0 mm
GROUND CLEARANCE- 0 mm at front due to forks, 0 mm at sides and rear due to skirts 7 mm with out, the skirts are hinged so flop over when the robot is flipped
ARMOUR- 12mm polycarbonate
MOVEMENT- panic now uses 6 Vulcalon wheels to give extra pushing power
POWER- 2 x LEM130€™s on 36 volts
WEAPONS- on the front the robot has a pair of invertible lifting forks, the forks are sort of like those on panic attack, the forks are powered by 2 linear actuators
STRENGTHS- Low ground clearance
WEAKNESSES- previously lost to spinners!
NAME- Rammy Mk 3
SHAPE- Invertible box with front hinged wedge
COLOUR- Blue
WEIGHT- 94kg
SPEED- 20mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- 0mm at the front due to wedge this is both ways, 0mm at sides and rear due to skirts 8mm without, the skirts can be taken off if they aren€™t needed for the fight
ARMOUR- 4mm Hardox
MOVEMENT- it has 6 inner vulcalon wheels
POWER- it uses 2 x lem 130€™s
WEAPONS- The front wedge can lift up and down powered by a linear actuator, this is only used if the opponent is winning to help get aggression points from the judges. The wedge is hinged so works both ways up however the lifter isn€™t as affective when the robot is flipped though it still works
SRIMECH- Invertible
NOTES- Rammy finally comes to the fra after entering frw 8 and some arc tourneys
STRENGTHS- Compact in size, great pushing power
WEAKNESSES- Comparatively Light
have fun with that plus my 2 real robots
Thanks Martyn! :)
What about my real robots?
Timmy... the tournament was filled up before you came back...
there always is the valid point that 3 of the entrants havent entered ANYTHING yet, out of them, AJ said hed enter his machines over the weekend
Nick and Matty, who also came to this topic too late (after all places filled up) said theyd like to enter BEFORE you did
so basically, here are 15 people willing to enter a 12-people tournament, and youre last in line
so theres the reason your realies arent on the list
Okay, Alex MacWilliams and Andrew Jackson are the only two left with no robots entered. Either post them or Ill let Matty and Nick take over. :proud:
(Message edited by kane on April 23, 2007)
OK, for the sake of keeping my place my team will line up something along the lines of this:
SOR
ForcePower
GigaByte
Wedga
Aneurysm
Axeon
Psyclonised
Typhoon 2
However some new versions are done/half done so Ill try and get them up later on. If I dont, just use the latest versions that you can find please.
Aaron has sent MDU4 to me over e-mail: if you want a look at it, its on me and Martijns forum.
And a correction to my previous statement: Chris Cooper also has no bots in. :proud:
Uh, bump...?
Went a minute doesnt that mean I can enter if 3 people havent put in their bots if so then put in mastiff instead of my vapourbot.
You ever heard of grammar? And also...
Went a minute
So? I went for several minutes.
No. Youre banned from this tournament on account of being plain arrogant. Now please, just GO. And Kane, leave this message on, and dont edit it.
Kody any stats that you have on your forum that arent in here would it be possible 1. to have a link to your forum or 2. post them in here
as 1. it would be nice to see them and 2. i am lazy and cant be bothered to go and find them,
Martyn...
1. http://strickenone.proboards99.comhttp://strickenone.proboards99.com
2. Dont be lazy :proud:
Soz I forgot to put wait instead of went I wish I actually read before I type.
Sign-ups are still open, you know, I need three more places.
Ill try and put something up, see what stats Ive got that can have a little modification.
Well, AJ, if you dont get your updated entries in in a week, then I will take your previous stats.
Alex MW, are you in or not? =P
Well, sorry, but Im taking your previous stats, AJ.
Alex MacWilliams, get your entries in. Matty, Chris C, fight over the last spot. :proud:
