Featherweight Database
I dont know whether to laugh or cry. Only 2 posts above yours I said Im counting the days untill we see Even bigger daddy on the database- a mini storm 2.....
and now, 3 days later, we get a mini storm 2. Oh well, cant complain. Look forward to seeing it in March:-)
If this one aint work, nothing will :)
yeah, if this one doesnt work you might come down to reality and build a 2 wheel drill powered box that might actually work, and *gasp* win because of it.
Hmm, in fairness big daddy sounded not too bad, although I shall reserve comment untill I see it. I think you should concentrate on just one design tho, and battle it and improve it and re-battle it and improve it further, instead of getting too easily distracted by other designs- it seems you loose enthusiasm for your robot too quickly- you need to stick with it and work on it to make a winning design.
People forget, Ewan has been on robots wars, something some of us have not yet achieved.
He has also build numerous robots, actually built them, and faught some of them, ok they might not have been the best in the world but we have to start somewhere?
Ewan ran the spinnymaul (forget the exact name) at the RCWars event, and it was damaging, reliable, and did not break, even when being crushed by venom.
Ewan does make some silly claims on the net but go easy on him, hes as much right to post as anyone.
James
Cheer, James.
P.S. (is your email running again yet?)
Torque
Type- ehm.. Axe
Height- 10 cm
Length- 45 cm
Width- 45 cm
Speed- 22 km/h
Drive- 2 x 150w graupner 700 bb turbo with 1:11 reduction on 100 mm bickle wheels (4WD)
Power- 1 x 2.5 Ah 12v Hawker D-cel with electronize 30 amp
Chassis- polycarb
Armour - polycarb
Weapon- 1,5 kg axe with 500 watt startermotor, 100 km/h :)
Status- being built
Turbulence (maybe Turbine 4)
Type- LP co2 flipper
Height- 100mm
Length- (not sure yet, depends how small I can get it)
Width- 450mm (I think)
Speed- 14-20mph (I think)
Drive- Custom made vulkonized wheels + 24v gold€™s
Power- 3amp Nimh
Chassis- 1.75mm hardened stainless alloy + 6mm T6
Armour - Stainless and t6 anodized Ali (whatever I got, I use)
Weapon- 10-16bar flipper
Status- bag of bits waiting to be put together
Regards
Dave moulds
Team Turbine/PLF
InXistence 2 (INX II)
Type- Full Body Spinner
Height- 12mm
Length- 300mm
Width- 300mm
Speed- unknown
Drive- 2 x 12v 35W Bosch Motors
Power- 2 x 7.2V 3000mAh NiCads
Chassis- 10mm Polycarbonate
Armour - 2mm Ti
Weapon- Spinning Ti Body with 12 teeth
Status- All parts waiting for assembly asa motors arrive
WOW!!! It must have been expensive to fit everything into a robot thats only 12 mm high?
It must be a Full body Thinner :)
LMAO @ Rob.
He must have used lots of metholated spirits :)
Blackguard
Type- verticle spinner
Height- 900mm
Length- 1075mm
Width- 900mm
Speed- unknown
Drive- one gold motor @ 4:1 reduction
Power- 24V 2400mAh NiCads
Chassis- 5/8 box steel
Armour - 2mm poly
Weapon- 800mm spinning bar driven by a 12v gold @ 24v
Status- part built may be done for preston event.
not the most sensible bot I have ever tried to build and those dimensions are correct.
Sam
team cut corners
Having just bought the inspire DVD and Im now totally convinced that Ive got to build a mini tanto.
Bought a motor today and its seems nice best bit is its 1/2 the size of the motors in Tanto.
type of bot- rambot
height- 150mm
length-275mm
width-300mm
speed-approx 15mph
drive-technobots medium power drive
power- 2x24v 1400mAh NiMH
chassis 6mm T6
Armour- proberbly 6mm poly
weapon-rambot the mini version of The full body hammer :)
status-collecting parts gimme a while
Craig
where did you get the inspire dvd? i put my name down for the advance purchase at the event and then again on the website and havent heard anything since.
Joe Townsend
Team Cut Corners
Ed was selling them at Brighton, but my current understanding is that competitors will get a free copy, which will also contain more than the version being sold over the weekend.
for those at Brighton, you may have seen the insides of this already
Whiplash
Type- airport (international fights only)
Height- dunno yet
Length- dunno yet
Width- dunno yet
Speed- dunno yet
Drive- 2, possibly 4 rcwars 600 motors
Power- 12v nicads, oh, might try NiMh actually.
Chassis- duralium/titanium
Armour - duralium/titanium/polycarb/gaffertape
Weapon- Mwa-haa haa
Status- got the gubbins, need to strap wheels and a ridio to them. a month maybe?
Joe - dont worry, everything is in hand and youll be getting a copy !
Ed
http://www.stormrobot.comhttp://www.stormrobot.com
P.I.M.P. 2
Type - 4WD Invertable Vertical spinner
Height - 180mm
Width - 388mm
Length - 480mm
Speed - dont know
Drive - 2 x 12v drills at 24V
Power - 24V NiCad
Chassis - 12mm and 6mm Polycarb
Weapon - 150mm diameter spinning disc powered by an EV Warrior
Status - Drawn up on autocad, starting to collect parts, will not be operational untill P.I.M.P.anought gats trashed/retired so i can steal speed controlers etc.
forgot, I got a featherweight running at the moment in the league.
Half-wit
Type- simple melty brain, kinda like gentle heater brain
Height- 120mm
Length- 450mm
Width- 450mm
Speed- um.... 20ish mph, dunno
Drive- 2 golds, might do something clever with em later.
Power- 21.something volt nicads, going up soon
Chassis- all ali, mothing special
Armour - again, basic ali.
Weapon- it drives in circles and has big teeth (grrr)
Ill be putting up the new stats on Annihilation soon as the weapon motor gets here, but the 4kg rotor is going back onto the robot again :proud:
-=UPDATE=-
WEIGHT - 6KG!!! (why cant i build a 12kg feather lol)
Height- 12mm
Length- 300mm
Width- 300mm
Speed- unknown
Armour - 2mm Ti
Status- Chassis built waiting for drive axles and body! before some real testing is done :D muahaha
I didnt know Bosches were 12mm high :).
Hehe, the Full Body Thinner is back!
Hey Joe...Vertical Invertable Spinners are copyright to us! :proud:
By the way, do you need any help in retiring P.I.M.P ? :)
I would like to get my next one nearly battle ready before letting you loose on the old one (although i imagine it is going to take more than superficial scratches in preston). And yes I did copy your robot and then added what I hope will be improvements (disc rather than bar, 4WD, more powerful weapon motor) I was hoping for a cross between Vortex, Scorpion Jnr and PIMP 1, I think it has a lot to live up to :sad:
Joe Townsend
Geoff, you havent thought about making a website for Scorpion?
Christian,
A website is under construction right now. May be a couple of weeks yet. http://www.teamscorpion.co.ukwww.teamscorpion.co.uk
Joe,
P.I.M.P is a superb machine and regardless of what gets said on the forum in good humour, I have no intention of gratuitously damaging it or any other machine in a friendly white board. (But seriously, just watch yourself in a league or comp. fight!):proud:
I would love to see this new creation of yours.
I see you are proposing a 4 wheel drive machine like P.I.M.P for this spinner...One question...How the hell are you going to do all of that in 12Kg!!? :)
Geoff.
with great difficulty :proud:, probably by ignoring all that armour stuff everyone keeps on going an about
I know you would never cause unnecessary damage, it is the necessary damage im scared of :sad:. I just hope this time i dont have to fight you in the league.
See you at preston
Joe Townsend
see he is learning from me with this no armour lark.
2.59 FW (with thanks to Adam Clark)
Type- 4wd Vertical Spinner
Length- arround 400mm
Width- around 300mm
Speed- unknown
Drive- experimenting with different setups
Power- same as above
Chassis- 10mm Polycarbonate and 10mm Ali
Armour - Stainles Steel
Weapon- Vertcial Spinning Disc
Status- Parts and designs atm no main chassis as off today
Type: flipper
Drive: bosch 35watts
Power: 2 x 7.2v 3000mah ni-mh
Chassis: 5mm polycarb + stainless steel
Armour: Stainless steel
Weapon: Flipper hopefully 16 bar with buffer
Status: in the build http://www.freewebs.com/kennyrobotwww.freewebs.com/kennyrobot under robots and KENNY new
thanks
kenny
teamkenny
Name: Micro Mute 2
Type: 4WD Rambot
Drive: 2x 12V Bosch 120W
Power: 24V 2.4Ah NiCad
Speed: 30mph
Speedos: 4QD NCC-70s @ 50A
Chassis: 16mm Square Ally Bar, 6mm Ally Plate
Armour: 4mm Polypro... soon to be Gr.5 Titanium
Weapon: Gr.5 Titanium Scoop and Spikes
Status: Built :)
There are some photos of the Featherweight smash up on my website, if anyone wants a look. Also a full diary of the past 3 years of building featherweights.
http://www.cuebruteforce.8k.comhttp://www.cuebruteforce.8k.com
Type: Spinner
Drive: Technobots wiper motors
Power: SLAs
Speed: sssslllooowww
Speedos: Electronize 15amp cpus
Chassis: Urm scaps of metal I had + lodsa rivits
Armour: 3mm t6 + stainless + 6mm poly
Weapon: Bar spinner
Status: Gimme 2 days and some Gaffa to finish it!:)
Reason for build: Turbulence is taking to long!
Regards
Dave moulds
sounds like a well engineered robot then dave :)
kenny
Name: Andrew Kenworthy
type: Roboteer
Wepon: Extreme sarcasm :proud:
Regards
Dave moulds
