yeah but I've got several sets of spare gears kicking around. Just let me know what you are after and I can probably get you sorted with enough to run a couple drill motors with all metal gears.
Ok cool. Thank you! I'll be in touch
How on earth are people getting these motors to run at above 18v?! I thought that would be their limit? Is it a case of run them until they blow?
you don't need to run them at their limit. Chances are that running the motors at the rated voltage with anything larger than a 60mm diameter wheel makes the robot completely uncontrollable.
