on my previous post i meant to say the gas in my robot can now be turned on by hand or by tool :D
Hi guys, the obvious way to go with this it seems to me is to build a robot that has the gas valve immediately behind the access panel with an M10 nut (17mm spanner) welded on the handle.
In this way the gas can be turned on/off with or without a tool safely.
Mike.
I know I dont have a flipper or any thing, but from what I have seen, I agree with mike. you should be able to turn the gas of safely by hand but to make it safer you should be able to use a universal tool to turn the gas off.
