Shape: Truncated Pyramid with wedge at front: See Pic
Colour: Red & Black: See Pic
Dimensions:80X70X75
Drive: 2 LEM 130s @ 36V geared at 5:1
Power: 6 NiCad 300mah batteries @ 36V
Motivation: 4 Hardox wheels with a Urethane Rubber coating (Is this allowed?)
Speed: 10 MPH Average - 15 MPH Max
Armour: 5mm Titanium
Ground Clearance: 0MM every where thanks to skirts and wedge, 6mm under skirts (too low?)
Turning Circle: 0
Weapons:
1: A large 15 KG drum sits on top of the robot, it is powered by a S28-400 Magmotor and spins at 3500 RPM and is armed with 4 2kg hardox bars that are the length of the drum
2: The wedge at the front houses a flipper similar to Warrior SKF, it takes it's power from the spinning drum and can turn over 300kg and toss 500kg
Srimech: The drum can easily self-right the robot, but the flipper can also do an equally good job.
Pic:
