Martyn’s RW Extreme 2008
I want to enter my new bot:
Triplicate Bot
3 part clusterbot
All parts are the same.
Shape: Cube
Speed: 30mph
Dimensions: 5cm high by 20cm long by 20cm wide
Colour: Silver
Ground Clearence: 0.1mm ground clearence
Turning Circle: 0
Weapon: 1 Powerful axe on each side of each clusterbot making 12 axes in total.
Armour: 6mm titanium
Drive: 2x S28-400 Magmotors powered by 3x NiCad packs
Srimech: the axes, and a steel bar connected to a Mag Snapper on top of each clusterbot
Notes: One of my first bots. A very tough, yet fast, 3-part, and deadly clusterbot.
Also have it in the World Champs representing the USA.
Theres no way youll fit two Magmotors, three nicad packs and four axe mechanisms in a 20cmx20cmx5cm cube.
Just for the record, I have a little 3kg sumobot that I entered in the UK Robotic Games sumo which was 20cmx20cmx20cm roughly and I struggled to fit in two cordless drill motors and two small drill nicad packs into that size. Need to revise your dimensions mate
Ah, flaming to do, how lovely...
3 part clusterbot
Okay.
Okay.
Shape: Cube
A cube is a shape that has its dimensions equal to each other. Your dimensions dont quite work out, so you might wanna change this. :proud:
Speed: 30mph
Impossible. You will never get that speed out of a 33.3kg (thats what Im assuming their weight is since you DIDNT SPECIFY ANY WEIGHT AT ALL) bot, and especially not with 2 S28s. Keep the Mags, add another NiCad Battlepack, and drop the speed to about 12 or 15 or something around there. Should be decent.
Oh...god. Those dimensions are so unrealistic I cant believe you actually thought they were legit. First of all, S28-400 MagMotors are 7.5cm in diameter, which defeats your current height, so Id recommend a height of something over 10cm. As for length and width, Id drastically enlarge them. 55 and 55 each would do it.
Colour: Silver
Okay.
You will have the hardest time moving around. Even 2mm is pushing it. Go for 5mm or over.
Turning Circle: 0
Okay.
So many things wrong there. 4 axes on each bot will most certainly put them overweight. Go for one axe each. Whats powering the axes? Whats the axe head made of?
A bit too much. Go for 3 or 4mm.
You dont need the steel bar if you have an axe on top.
I would REALLY revise those stats, Mark.
Updates:
Dimensions: 10cm high, 55cm long, and 55cm wide.
Drive: 2x S28-400 Magmotors powered by 4x NiCad Battlepacks.
Armour: 4mm Titanium.
Ground Clearence: 5mm
Weapon: 1 Hammer on top of each bot. The hammer has spikes on it to prevent each part from turning over on its side.
Srimech: Hammer.
Weight: 100kg. Each part weighs 33.infinite 3kgs
Now is it accurate?
(Message edited by corsair_lightning on March 25, 2008)
Not really, what is powering the hammers for instance?
Ok, you have dumbfounded me, what is a Mag Snapper?
A Mag Snapper is an ordinary burst motor with Magmotor decals on it. It also has a built in pneumatic system to create more power. Plus the pneumatics cause the Mag Snapper to be ultra quiet.
Can I enter the world championship?
Brutalis 1.5
Weight- 100kg
Shape- Like Dantomkia, but much lower and heavier at the front and wider flipper (80 cm diameter 4mm hardox shovel on the front)
Dimensions- 80x80x25 cm
Power- 3 x NIcad battlepacks powering 2 x S28-400 magmotors running at 24v
Locomotion- 2 x go-kart wheels inside the robot
Ground Clearance- Effectivley zero all around due to the shovel at the front and skirts on the sides and rear, behind the skirts and shovel it is 6mm
Turning Circle- Zero
Top Speed- About 15mph
Armour- 4mm thick hardox all over, side skirts are 2mm thick hardox
Weaponry- Co2 powered flipper running at 750psi, 2 x 70mm rams powered by 2 x 3kg bottles, approx.20 flips per battle
Srimech- The flipper can easily right the bot quickly and easily
Representing the Republic of Ireland
System Shock
Weight:110kg (tracked)
Shape:Like Panzer from Robot Wars 3, but with skirts on the front and rear with a Tornado-style wedge at the front
Dimensions:75 x 75 x 20
Power:4 x LEM-130s runnung at 36 v powered by 6 x NIcad battlepacks
Locomotion: 2 x steel tank tracks
Ground Clearance:Effectivley zero due to wedge and skirts, but 6mm behind skirts and wedge
Turning Circle: Zero
Top Speed:About 10mph
Armour:4mm thick hardox, 2mm thick hardox skirts
Weaponry:3mm thick hardox scoop at the front and 2x steel ramming spikes at the rear
Srimech:Invertible
Representing the United Kingdom
That OK?
