Vapourbot Annhilators!!!!
Advice, criticism and flames still appreciated:
NAME- Death Threat 0.1
SHAPE- Long box with rounded back,
COLOUR- dull grey all over
WEIGHT- about 100kg
DIMENSIONS- L:95cm W:70 cm H:30cm
SPEED- 10mph
TURNING CIRCLE- 0m
GROUND CLEARANCE- 10mm all over
ARMOUR- 5mm titanium
MOVEMENT- Tracks with 2XBosch Motors with 3 Ni-cad battery packs at 24 Volts
WEAPONS- Horizontal crushing claws at front made out of titanium with 4.25 tons of crushing power
SRIMECH- Invertible. Side spikes to stop it resting on its side
NAME: Axes of Evil
SHAPE: Hexagon, sloping in to a point in the middle.
COLOUR: dark green.
WEIGHT: around 100kg
DIMENSIONS: 60x60x50
SPEED: 12mph
TURNING CIRCLE: 0mm
ARMOUR: 20mm polycarbonate
GROUND CLEARANCE: 0mm all over with skirts, 15mm with.
MOVEMENT: 2WD inside robot. powered by two Bosch motors running at 24 volts.
WEAPONS: Rack and Pinion axe mechanism powered by two CO2 tanks at 160psi. It has two terrorhurtz style heads, one on either side of the shaft, because Axe of Evil doesnt work with the pun, and the name has to be accurate.
SCRIMECH: the axe has spikes sticking out to aid self righting from any angle.
1. Nitro-Gene
2. MeCannibal
You can find them in Fowler Fic Wars 5.
not bad Danny, nto bad at all :)
So matty you want to register?
Ill see if anyone else does first.
Well theres only one spot left.
Well if I am not too late Id like to enter:
1: Eternia
Weight: 98 kg
Speed: 18 Km/hour
Lenghth/with/height: 120 cm/65cm/35cm
GC: 5mm on the sides, 10 mm on the back and front so it wont run aground on a toothpick sticking out the floor. the flipperarm is pushed flush to the floor with bungee lifting the frontend.
Drive: 2x3 Graupner speed 900 BB torque @ 24V Geared down 20:1 on 15cm wheels.
Weapon: 100mm bore x100mm (4 tons) stroke ram Gravity style flipper with 2 1/2 bsp burkert inlets and a 3mm hole as outlet. A 2 compartment aluminium buffer of 4 Liters being fed by 2 2kg CO2 bottles. The arm levers it down 3:1 giving 1300kg of force at the tip of the arm.
Chassis: Main frame holding the ram and flipperarm is 40x40x4 mm welded box section, the baseplate is 4mm 7075 aluminum and the armour on the sides and top is 40mm HDPE. The flipperscoop is hardox 450 6 mm, the arm itself 40x40x4 box section.
Batteries: 60 GP3700 NiMh cells, 20S3P, giving 11.1Ah@24V. weight of the pack is 4 kg.
Special Notes: All black, with red markings at the sides.
2: GBOD
(Giant Bell Of Death)
Full body spinner
Weight: 99kg
Speed: 10 km/hour
Diameter: 75cm
Height: 45 cm highest point, outer ring 25 cm
Ground clearance: 10 mm all round
Drive: 2x Bosch GPA 750 on 36V with 15cm wheels
Weapon: Full body spinner, outer ring is 6 mm Hardox 450 with 2 Hardox 450 teeth welded in, one if which angled downwards and one straigth out, like Typhoon 2, it spins a maximum of 2000 rpm.
Top is 3.2 mm Hardox with 4 holes cut out to reduce weight.
The disk is powered By a Plettenberg Predator Brushless motor with Jeti Spin 200 ESC at 36V.
http://www.youtube.com/watch?v=gzCDxed4blUhttp://www.youtube.com/watch?v=gzCDxed4blU
(Message edited by leorcc on December 23, 2007)
Mark, SHUT UP. AND STOP BUMPING OLD THREADS. DAMNIT!
MARK STOP BUMPING OLD TOPICS
