YUCK!
Theres summat VERY WRONG with your Transmitter or reciever!
Could you check that you have the same freq crystal in both your Transmitter and reciever.
Could you also check that the transmittter and reciever are both 40Mhz.
YUCK!
ive done that and tried 2 other sets of crystals
edit:
even fresh batteries
(Message edited by rob on August 06, 2007)
Seems that a Spektrum would indeed be your best bet.
BTW .... There has been one case reported on the Forum of a miss match in Transmitter and Reciever frequencies ...I.E. One being 40Mhz and the other 35Mhz.
Are you sure yours are both 40Mhz?
Robert, You have now tracked the problem down to the radio link between the transmitter and the receiver. Thats progress. Once you have eliminated mismatched crystals and the possibility suggested above that the tx and rcv might be on differnt bands, the next thing is to find someone with a 40 MHz tx and rcv that work well and use them to isolate the fault to either your tx or rcv. Once that is done you can take the offending equipment apart and look for loose wires or send it off for repair.
Robert as the second post says
buy a spektrum
i did not belive this i borrowed one and NEVER went back
