The ram looks something like 60mm bore x 300mm stroke?
the main ram body is 60mm thick, and the body length is 300mm, with the flipper open the piston rod as it were itself is 18mm thick and 190mm long, or somewhere round that, hopes this makes sense:crazy: the hydralics will only be removed if i start having serious weight issues, but i will have to see what happens when its on the scales! also i dont think that room will be an issue on this machine, theirs seems to be amble space around the robot i think,
(Message edited by ady on May 15, 2007)
Your not going to be chucking robots across the arena with a 50ish mm bore ram running @ 10 bar....itll only self right you and turn opponents over.
Beef up the flipper arm and you could run something competative like a 80mm or 100mm bore ram @ 10 bar ......15 bar would be best if you can get / afford the bits.
