Reciever Battery packs
These are fairly normal switch / charger harnesses ... ignore the blurb calling them a receiver box.
http://www.abcmodelsport.net/p389307/CHARGING-SWITCH-HARNESS-FUTABA.htmlhttp://www.abcmodelsport.net/p389307...SS-FUTABA.html
http://www.abcmodelsport.net/p389310/SWITCH-HARNESS-FUS-CHARGE-MOUNT-PLATE-JR.html?image_id=148504http://www.abcmodelsport.net/p389310...NT-PLATE-JR.ht ml?image_id=148504
(Message edited by woody on June 15, 2007)
is it like this?
http://cgi.ebay.co.uk/HPI-FIRESTORM-POWER-SWITCH-RECIEVER-BATTERY-CASE-NEW_W0QQitemZ280120389269QQihZ018QQcategoryZ19168Q QrdZ1QQssPageNameZWD1VQQcmdZViewItemhttp://cgi.ebay.co.uk/HPI-FIRESTORM-...CASE-NEW_W0QQi temZ280120389269QQihZ018QQcategoryZ19168QQrdZ1QQss PageNameZWD1VQQcmdZViewItem
well the one currently the switch has the end to go into the reciever, and the end that connects to the battery box just has space to fit a 2 wired attchment in, if that makes sense. but the reciever has three
so three wont fit into two
thanks alex
But there are only 2 wires involved even if the plug has 3 pins.
Hi Alex,
I use the futaba switch,it has an extra lead which plugs in to a standard charger so that when the switch is off it allows you to charge your battery without taking it out of your bot. i found that pushing and pulling the reciever connector ends up with loose connections which leaves you dead on the arena floor:sad:
My switch is on the side of a small plastic box which houses the reciever, battery and scorpion speed controller.
right the battery pack has a three pin wide attachment, even though it uses to wires. so therefofre will not fit into a connector 2 pins wide, its like trying to fit a square pin into a circle hole
alex
would this one be suitable from technobots?
3601-032
alex
