I read the rules a while after asking for a reserved place. If people dont want me in their tournaments, just tell me so. Youve just lost an entry Dan.
He doesnt not want you. He just dosent want you reserving a place beacuse you take forever to make stats.
using double negatives are bad very bad
Can it, Martyn.
*puts Tony in a can on Banked Beans*
Im entering no tournaments which dont allow me to reserve a place, simple. I find it absolutely riddiculous.
can what exsasctly? the sun the potatos?
ORKA MK4
Weight: 100 kilos
Body Shape: Behemoth
Speed: Some 15mph
TC: 0
GC: 2mm, 0mm at front.
Wheels; 6 inner
Armour; 7mm titanium
Power; 3x 12v batteries, powered by a couple of Magmotors
Weapons; A Behemoth like bucket scoop, made from titanium, and quite capable of lifting 300 kilos. It has a claw like device to grab an oppodent, like the claw on Mantis. The scoop is pnumatically powered, and has about 45 odd flips.
Srimech: It has a dorsal fin on top used for self-righting
Inspiration; Ive always liked Orcas. Adding the K made it sound more dangerous.
Strengths; Weapon
Weaknessess: Hard to turn
BIO
Every big team needs some big star to bring in the crowds. My big name is Orka MK4, representing Team Dinowarrior in all its glory.
No one is faster, smarter or more agile than Orka Mk4. When charging, other robots need to get out of his way. He can flip just about ANYTHING that doesnt take the warning, or simply grab hold of them. Hes ready for battle! Are you?
DIE-CERATOPS RE-INVERTUS
Weight; 100 kilos
Body Shape: Wheely Big Cheese
Speed; 15mph
TC; 0
GC; 0mm at front, 3mm at sides and back.
Wheels; 2 inner, sticking out only slightly,
Armour; 8mm titanium
Colour; Green, with Killer Carrot style wrinkles, mouth and eyes. One of the eyes has a plaster over it, the other is a black eye. A few bandages are painted on this time.
Weapons: A huge Wheely Big Cheese style flipper, capable of flipping a tonne or so.
Srimech; As the name suggests, the robot runs inverted. Bars prevent side strandings, and the back is rounded, so stranding THAT way is outta the question. The flipper works upside down.
Inspiration; Ive always liked Dinosaurs. This is a pun of Triceratops. The Invertus part is pretty obvious.
Strengths; The ability to work upside down and still be able to use its weapon, now easier to control.
Weaknessess: Tengu VI
BIO
Orkas cute-on-one-side-pure-hell-on-tuther friend, Die-Ceratops is equally as powerful and as nippy as his buddy. In the arena, he can get to oppodents/victims in record time. Then, once his flipper is underneath them, they can kiss the ground good-bye. Of course, hes teamed with me, and I can be rather protective over him...
CYCLONE FORCE 2.5
Weight; 100 kilos
Body Shape; Storm 2
Speed; 25mph
TC; 0
GC; Side is 0mm due to skirts. Back is 2mm. See set-ups for front GC
Wheels; 6 inner
Armour; 7mm Titanium.
Power; Similar stuff to what Storm 2 uses.
Colour; A blue-ish grey tone all over.
Weapons; The robot has 5 set-ups, 2 brand new...
SET UP 1...A lifter device, similar to Storm 2. In theory, it can lift 190 kilos. The front makes a wedge and results in a 0mm GC. However, the wedge is useless upside down.
SET-UP 2...A pair of Kan Opener style claws, with about 4 tonnes of pressure at the tip. Front GC for this and Set-up 3 is 1mm.
SET-UP 3...A Disc-O-Inferno style disc, reaching speeds of up to 3000rpm and with similar damage capability to this dangerous bot (I mean, look what it did to Panic Attack).
SET-UP 4...Two 30cm long spikes, which, combined with the speed of the robot, can easily penetrate weaker armours (Id say anything 4mm thick or less, minus Steel, is in a bit of trouble).
SET-UP 5...The most risky approach, A simple bucket scoop, like X-Terminator. The scoop is static, but can get underneath virtually zero ground clearance. Its front is 0mm.
Srimech; The robot runs inverted, the sides are protected by the skirts and back stranding is impossible. Set-ups 2, 3 and 4 work upside down.
Inspiration; The original Cyclone was named because it is the name of a storm and it sounds threatening. The force came later, after it became a pusher.
Strengths;Raw power
Weaknessess;Lack of control, Set-ups 1 and 5 do not work upside-down.
BIO
When Cyclone Force 2.5 is in the game, every other piece of metal is scrap! Cyclone can travel across the arena with great speed AND power. His interchangable weapon system means NO ONE is safe. Thank goodness hes harmless when turned off.
Last one for today...
LEPROSY INFECTION
Weight; 100 kilos
Body Shape; Tetanus Booster
Speed; 18mph
TC; 0
GC; 2mm
Wheels; 4 inner, top sticking out. Wheel flaps are situated either side of the wheel to protect them.
Weapons; A very large, very dangerous vertical drum, capable of reaching speeds of 4000rpm. The teeth on the drum are curved upwards so they can flip as well as damage and very sharp at the tip. There is a reason for this...
Weaknessess; Wheels may be vulnerable to axes
BIO
When youve got sharp teeth, sickeningly bright green paint and a name of a skin disease, battle invitations are pretty remote. So, hes loving life in the Robot Wars arena where he can make others sick. Leprosy Infections drum is killer! And when hes upside down, those teeth start gouging out his prey. Grrr...
The rest later.
