New link design
I was half expecting the response to be dont built it like that, then!
I think just in case I will take a link extension cable which plugs into one link and provides the link contacts on the other end of the link, right next to the other link. It would lengthen the battery leads (not good) but is better than being sent home.
Id be interested in knowing more about this featherweight, Leo - do they have a website?
New link design
It just happens to be mine :)
It works on the stinger principal. most of the weight is in the wheels, about 8 Kg. So the motors/batteries/etc spin round the axle. Newton says if you spin the wheels one way with a certain force, the axe goes the other way with the same force.
On the down side.. each wheel has to have its own batteries, reciever, link, etc.
http://www.dutchrobotgames.nl/cgi-bin/robots/49http://www.dutchrobotgames.nl/cgi-bin/robots/49
http://www.bugs.nl/media/album/index.php?path=L3Byb2plY3RzL2Z6bjEvhttp://www.bugs.nl/media/album/index...plY3RzL2Z6bjEv
http://www.bugs.nl/media/album/view.php?&path=L3J3L2Fob3kyMDA0L25sLWNhcmxpam4vSFB JTTA3NTkuSlBHhttp://www.bugs.nl/media/album/view....LWNhcmxpam4vSF BJTTA3NTkuSlBH
http://www.bugs.nl/media/album/view.php?&path=L3J3L2Fob3kyMDA0L25sLWxlby9JTUdfMDA xNi5KUEc=http://www.bugs.nl/media/album/view....LWxlby9JTUdfMD AxNi5KUEc=
New link design
Apart from having two links in our robots, I see we also both use bicycle chainrings and read Douglas Adams :) Nice work.
Those nylon drill gears dont look too happy though :)
New link design
Just thinking that usually all battery terminals and areas that could short must be covered. Judging from the photos this doesnt seem to be the case with your robot. In battle something could easily link the power back up to the robot.
New link design
I covered that in my first post.
New link design
Jim ......... I personally cannot see a problem with you having two seperate links, as you say it is very nearly a cluster bot so it two independant robots joined at the hip so to speak .. therefore I as Roaming Robots ARENA MARSHALL would be treating you as two robots which means i would expect to pull two links to disarm you......... Speaking from past expiriences so long as you and the arena staff ie myself or whoever is in charge of the arena at the time are aware of your arming and disarming procedures i have had little or no problems. AND DONT FORSEE ANY IN THE FUTURE ... PETE(ROAMING ROBOTS ARENA MARSHALL)
New link design
Good news, thanks for the feedback Pete.
New link design
For future reference...
Paul was entirely correct. One of our links did overheat, despite soaking them in phosphoric acid solution before our fight. We intended to fit the Anderson connectors but ran out of time before Magna. Luckily, our Hawkers survived to fight another day.
