HP buffer tanks
cheers chaps, ive removed the brass fitting and they both are 3/8bsp. The first one came off easily but the second was on rather tight! isnt it always the case. Ive also got a smaller bottle, similar to a sodastream bottle that i think is out of a water fire extinguisher, so might put that in as well (that also had a brass fitting onto a 3/8), so might have all three in!
HP buffer tanks
If you have gone to a bigger ram, what have you done with your old one ?
HP buffer tanks
nothing at the moment, but i think its more or less knackerd! it had new seals put in for the world champs, but it seemed to start leaking within a few events. i think the cylinder walls have got damaged.
HP buffer tanks
If M18*1.5 is the metric version of 3/8 bsp whats the metric version of 1/4 bsp ?
HP buffer tanks
http://www.adneish.freeserve.co.uk/threads.htmhttp://www.adneish.freeserve.co.uk/threads.htm
M14 fine is the nearest in physical size to G1/4 ...1/4 Gas .. 1/4 BSP.
