Will run it for days and days. You can use a pack like half the capacity.
is this better or still to big ?
http://hobbyking.com/hobbyking/store...arehouse_.html
That is exactly the same capacity. It is a different voltage though. Which were you planning to run, 4 or 3 cells?
im looking for max pushing power similar to an american bot i allways liked called panzer mk1 but smaller
TBH a beetle pusher can run for a long time on 1300mAh, as for voltage (how many cells), the motors Harry showed take 12v (3S) but can take 14.4 (4s) easily. General rule of thumb says they can run 1.5 times their stated voltage (which in this case is 18v (5S pack, near enough), but I can't guarantee how long they'd last. If speed and power is what you want, 4S will probably suffice.
im assuming that the arenas have a pit or other hazzard that i can shove opponents into as im guessing matches are judged in the same way that the tv show judged the big fights
Mine has a pit, and possibly a flip out zone, but no others planned for now.
does that mean its worth thinking about some form of active weapon??
Active weapons are very much encouraged :)
i can see me being really stuck in the future due to lack of machineing ability
