moved elsewhere
moved elsewhere
I do understand that, but testing has taken place with a 100kg load and it works fine but would have to travel around 3-5mph not the anticipated 10mph
I posted, but then decided it should go on another thread, so I moved it.
Ah ok, cool
Then you won't need a gear-up of 5-1, 3.5-1 or whatever. A 2-1 will do. 40 teeth on the motor, 20 teeth on the wheels.
In any case, for a housebot, 250W sounds extreem low power. If you know that the "original housebots" used motors like the Briggs & Stratton Etec with 11 kw of power and gazillions of Nm torque....
Where is the h/w house robot going to be used ?
