I think this should be an interesting robot to build, and follows the path of making featherweight versions of heavyweight icons.
the only difference this version is based on a heavyweight that didn't work properly. NOT JOHN'S FAULT I hasten to add.
The only disadvantage, this robot could only work properly on the Robo Challenge arena, as it is the only steel floored arena in the UK. I don't know are the floor panels bolted down enough? or the floor superstructure strong enough not to warp?
I hope to have a new Seraph robot for the UK champs too, that will be a sword or hammer. The difference is the ground clearance on it will be about 120mm and not less than 1.2mm
Good luck with the build Grant looking forward to fighting it soon.:)
