Re: prodigy evo
That's sounds pretty good then Leo! Having spoke to glen about those belts he did say the green ones were quite hard, but having a bit of slip is a good thing.
Be good to see a brushless spinner that works reliably on budget components.
What sort of current draw does it pull?
Re: prodigy evo
Re: prodigy evo
Sounds good, looking forward to the end result, spin down time isn't a issue :-)
Re: prodigy evo
Starting to take shape
15mm sidewall, 10mm top and bottom armor, a tad over 2 kg, of the 4 we had left , HDPE welded and reinforced , with some shape outside cube.
any remaining weight will go on more armour, maybe removable? when fighting these pesky spinners!
http://i464.photobucket.com/albums/r...7/image-10.jpg
Re: prodigy evo
The joints on the HDPE ain't milled right trough.
But bending 15mm HDPE accuratly is not easy, not even with industrial heatguns.
So, the hybrid solution. The joints are milled out 8mm deep, leaving 6mm thick HDPE solid. The rest will be welded and the ali supports replaced by Hardox angles.
Re: prodigy evo
Re: prodigy evo
Re: prodigy evo
looking very nice. cant wait to see it run!
Re: prodigy evo
test vid, next one will be a destruction test :)
http://www.youtube.com/watch?v=7rQ-rcU0c-k
Re: prodigy evo
