Do you know what the company that made the copy is called? Or do you have any spare/know any one who still has some spare? Unlikely, but I might get lucky :)
Sandvick does something simular, called Creusabro.
This stuff seems to out do Hardox considerably! I have a supplier in the UK, but minimum sheet size is 2.5m x 6m :x
As I told you, thin wearplate is rare.
Suppliers don't keep stock of it.
Found a sheet of 1.5mm Ti6-4 on ebay... (the seller says 1.2mm but on the sheet it clearly reads 1.5mm in 2 places) Is that thick enough for a base... it would be similar to LS4 but that never takes a hit
We use 2mm Grade 4 Ti on Bitza (TA6 in the UK) and it's super bendy. That's what makes Ti such great armour, as a base plate though it may have too much flex.
A lot of it though is about how you use it. Take an oven shelf for instance, that is some of the crapest, thinnest sheet steel you'll ever come across but it's rigid enough for a shelf because of the way the edges are shaped.
Depends on the grade as well when it comes to titanium. Grade 5 is the stiff stuff that accounts for the majority of world wide production. Grade 2 can bent into all kinds of shapes without snapping. I used to know what grade 4 was good for but it escapes me now.
I believe grade 4 is the highest 'pure' form, before a large majority of it's make up is Vanadium and Aluminium like Grade 5 upwards.
Grade 5 also has the highest elasticity value, which is what makes it so popular in robot armour. Just bounces right back!
well this is the first one I found...
http://www.ebay.co.uk/itm/Titanium-plat ... 564wt_1396
Pure grade 2 so i am guessing its to flexible for a base but might be good for top armour...
Here is the other...
http://www.ebay.co.uk/itm/Titanium-shee ... 500wt_1413
1,5mm,or 1.2mm Ti64... Something tells me neither is really suitable for a base
64 probably stands for the Aluminium-vanadium content, and that will mean it's grade 5.
£25 for 4.15kg of good grate Ti... I'm tempted. Looks ideal for a monocoque Raptor.
