Cheers Jamie! Lets hope it comes good, would be a good battle 1v1
Had a harsh draw for the UK championships which sees Predator against 2 nasty spinners. I do have around 2 kg to play with but i may just leave it if the machine does well in testing. I need to beef the front of the chassis up but other than that it may just get some lead in the base to lower the cofg. Yesterday i made an end stop buffer for the head to stop it going to far back and hitting itself. Just need to make a little pic up so we can add limit switches to the head and arms.
Here comes the champs!
magnets?
Not keen on magnets as I havent seen them work well that often. I may try some for testing and see how it goes. Im also rapidly running out of space lol.
Surprised to find mounting the weapon speedo and links is the biggest challenge of this build!
Unimportant bits then.... ;)
The links are a real problem... where on earth do you put them on Predator with out being too close to the disc or the arms
For the last 2 years we've done the links the night before :s It's a serious consideration that people always overlook.
james I would worry more about keeping it from the disc. I'm sure the arms could hurt if you caught your fingers in there but generally i like to have my link in a location that when I'm working out channels on the tx and it inevitably goes to full throttle without my input i can easily get the link out.
Top of the tail just below the motor, away from the disk and between the arms,
